steering o ring question
would a o ring problem cause sudden pump failure? and then come back on?
possibly if you're low on fluid.. It's a $1.00 fix and 20 minutes of your time so it's worth a shot.
Brian |
Instructions for changing the O-ring are here:
http://www.subaru-svx.net/photos/files/How-To/14304.pdf Aways check the How-To Documents link at the top right of the page for valuable information concerning maintenance and repairs. .
A bad O ring can cause leaking, and air leaking into the system. The first thing I would do is change the O ring and then if there are still problems, we can figure it out from there. Good luck.
There also a fuse in the fuse panel(by the driver's feet) that controls the power steering. I was piggy-backing my trans temp gauge into one of those fuses and shut down the P/S until I made a good connection.
Just another avenue to explore...
cbx-man '92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter '92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft '80 Honda CBX in-line 24 valve 6 cylinder |
- John ASE certified Master Tech W/ X1 Twin City Fleet repair, St. Paul, MN need work done? Have tools will travel
I strongly feel it was the pump, because I compared the steering with a pump installed and without it, with the pump on I have like 5 percent assist, without the pump installed it felt like the steering wouldnt move, thats how it felt a couple of days ago, but now it seems normal. I put a direct wire from the steering fuse the the steering computer. so i dont think its the system
Thread Tools | |
Display Modes | |
