Old 08-06-2006, 12:16 PM
Hohopirates's Avatar
Hohopirates Hohopirates is offline
JDM engine trouble
Hey Guys and Gals,
I am getting ready to drop in my JDM engine into my 92 and noticed something. There is a small sensor that looks like a bolt with 2 wires coming out of it. It is mounted into the rear of the intake on the passenger side under the air intake, the problem is the new engine has no threads for the sensor. Any ideas?
It's not a car..it's a boat!!
Old 08-06-2006, 12:44 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Swap the intake
Old 08-06-2006, 01:29 PM
Thanks Beav, my brother came to the same deduction. Is it from a 96 possibly or is just because it's a JDM motor?
Old 08-06-2006, 02:22 PM
Beav's Avatar
Not as old as Randy
It doesn't really matter, does it?
Old 08-06-2006, 06:21 PM
Originally Posted by Hohopirates
Hey Guys and Gals,
That would be the EGR temp sensor, that only the US version has. So as the ECU will be looking for it, best do as Beav says.
Old 08-06-2006, 06:34 PM
shotgunslade's Avatar
If you don't put it in, it will throw a CEL, with a 55 code. My hard-piped intake intake snorkus pressed against the sensor cable and wore through it, causing a CEL and code.
