Old 07-27-2006, 12:10 AM
redsvx94 redsvx94 is offline
Creaking noise during turning
Hi All,
My SVX is making noise near steering area when I turn the steering wheel towards all the way to left and right. It kind of sounds like creaking of hardwood floor. I can hear very clearly in the cabin but not really outside whether I open the hood or not. Noise is there both when parking and just idling. Did I ruin my steering column? Any idea how to find exactly where it's coming from? This started after it has been on rails for a while due to various work including timing belt and water pump. I don't think it is ps pump or belt. Thanks!
Old 07-27-2006, 12:17 AM
triumph1902's Avatar
triumph1902 triumph1902 is offline
It is likely that its your front upper strut mount making the noise.
________________________
92 Teal - Work in progress
Old 07-27-2006, 01:07 AM
Originally Posted by redsvx94
Hi All,
Noise from the power steering system, due to the presence of air in the fluid, is very hard to define. I was not convinced when I had strange noises, until I replaced the O ring on my car, which fixed it. This could be your problem and if so you can rejoice, as the fix is simple and inexpensive. Refer the how to section.
Old 07-27-2006, 06:29 AM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
I get a 'crack' when i turn, often when its at speed and the weight shifts to the outside.
Old 07-27-2006, 07:40 AM
Thanks for the replies.
Mine never makes any sound on speed. Only during parking or not moving when I turn towards all the way. Since it makes sound when not moving, I thought it was not a strut? I recently changed oring but the power steering pump area does whine a little. PS whining sound is distinctly different from creaking sound I'm questioning about. I thought it was not the pump since this creaking is coming from behind the dashboard or near steering column is, I think.
I could do oring change and flush again.
I saw a post about sounds possibly due to something called "clock spring". Could this be damaged if a car is on a rail for a long time?
Old 07-27-2006, 10:59 AM
LarryIII LarryIII is offline
Hi All,
I had that same noise. It was my left shoulder joint.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 07-27-2006, 12:11 PM
how much did it cost to fix it.... an arm and a leg
Old 07-27-2006, 05:34 PM
Any one who had a LESS serious problem ?
Old 08-08-2012, 10:48 PM
Marcus Marcus is offline
Re: Creaking noise during turning
Hi, since I am actually facing the exact same issue like stated in this post:
- cracking (not squeesing) sound only while turning the wheels during stand still
- no increased force neccessary to turn the wheel
- no noise while driving
- steering fluid reservoir filled to max, no leaks)
- ball joint replaced about 2 years ago
I am most interested to learn if/how this issue got resolved or if there are any ideas on the root cause.
Thanks a lot!
Marcus
Old 08-26-2012, 11:19 PM
Hi,
yust want to let you know: In my case the stabilizer links where shot.
Marcus
