Old 07-16-2006, 09:24 AM
seion seion is offline
Subaru Engineer Wanabe
Question Just got '92 SVX and need tranny cooler advice
I got a '92 SVX Pearl White last Thursday. 103K miles and one of the first things I need to do is install a tranny cooler. I have some prospects and I would like you to let me know what you think:
1)http://www.jegs.com/webapp/wcs/store...tegoryId=16861
2)http://www.jegs.com/webapp/wcs/store...tegoryId=13511
3)http://www.jegs.com/webapp/wcs/store...tegoryId=18275
4)http://store.summitracing.com/partde...5&autoview=sku
5)http://store.summitracing.com/partde...5&autoview=sku
Also, is this the right PermaCool ATF filter kit?:
http://www.jegs.com/webapp/wcs/store...tegoryId=18311
Cars I've worked on:
'05 Subaru Impreza STi, '02 Subaru Impreza WRX Wagon, '01 Toyota Celica GT, '98 Subaru Legacy GT 2.5 Sedan, '96 Isuzu Rodeo, '95 Jeep Cherokee 2WD, '94 Plymouth Sundance, '94 Subaru SVX LSi, '93 Subaru Impreza, '92 Subaru SVX LS-L, 2003 Subaru Baja.
Old 07-16-2006, 09:54 AM
immortal_suby's Avatar
Thread Killah
The filter kit is correct.
Not sure all of those coolers will fit - I have the perma cool # 12511 with fan in my fenderwell. It fits fine. Those look like nice coolers. As long as the dimensions are right and you can fit it then any of them should work. Try to get the biggest one that will fit.
Locker Link
2015 BRZ Limited 6MT
Old 07-16-2006, 09:56 AM
Thread Killah
Locker Link
Old 07-16-2006, 12:27 PM
I am having trouble seeing where that is mounted. Yes, in the wheel well, but do you have a pic that shows the relationship to where it is at?
Old 07-16-2006, 03:39 PM
Originally Posted by immortal_suby
Does this model have a thermostat or it runs all the time?
Old 07-16-2006, 03:40 PM
Maybe this will help:
Old 07-16-2006, 03:45 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
If you mount it in front of the radiator you won't need one with a fan on it. They have one made by perma cool at summit racing for like 45-50 bucks that would do the job perfectly. Just my .2 cents.
Old 07-16-2006, 04:08 PM
Thread Killah
No thermostat. I turn off the fan in the winter. Otherwise it runs all the time.
Locker Link
Old 07-16-2006, 04:10 PM
Thread Killah
The yellow box in the picture is the driver front airbag sensor
The fender liner is removed.
The whole setup is in front of the driver front tire.
The blue thing is the filter for my atf filter kit.
Locker Link
Old 07-16-2006, 05:42 PM
ATF Cooler position.
Matt the way you have fitted the cooler, would have to be the best position for it. It ensures effective cooling, while preventing the ATF heat from being feed back into the Air Con/engine, heat exchanges.
A bit harder to set up, but for areas of high ambient heat, it will keep the trans cooler, the Air con working cooler, and the motor staying cooler.
Old 07-16-2006, 06:22 PM
Do you know the size of your cooler w/ fan? I'm about to get the PermaCool ThinLine with 3'' x 10'' x 12.5" dimensions, but want to check w/ you first (http://www.jegs.com/webapp/wcs/store...egoryId=16861).
Old 07-16-2006, 06:58 PM
Thread Killah
http://www.perma-cool.com/Catalog/Cat_page13-1.html
It is the # 12511
Maxi-CoolTM Junior coil with 11/32" HB (ext) tube ends, with 10" electric fan module.
Unit size: 3" x 10" x 12-1/2" Electric fan: 10-blade, 4.5 amp draw, 25 amp fuse, 950 CFM.
Locker Link
Old 07-16-2006, 07:00 PM
Thread Killah
Thanks, Harvey. Even a blind squirrel gets a nut now and then
Locker Link
Old 07-16-2006, 07:43 PM
It is the # 12511
Oh geez, you gave me the part number like on the second post - sorry for missing that one; I'm such a n00b.... Awsome then. Ordering now and hopefully installing soon. Thank you.
Old 07-17-2006, 01:12 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
I like this one
http://svx-motorsport-accessories.st.../trancool.html
btw, I always mount mine in the dr side
wheelwell in front of the tire at an angle...
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
