Old 04-01-2006, 11:53 AM
pavanbabut's Avatar
Question how to deal with clear coat issues??
Hi,
Is there any way to get around with the oxidation issues of the paint due to clear coat issues?? Can we actually remove or scrub off the oxidation region and get back the original paint?
thanks,
-Pavan.
Old 04-01-2006, 12:02 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
1000 - 2000 grit wet sandpaper with plenty of water and be careful
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-01-2006, 12:07 PM
pavanbabut's Avatar
-Bill
Ahaaa.. its exactly what paul[92svx95] told me, but just want to make sure with you. So, can you tell me how to perform this job?? I dont mind working on it rather spending $2k-$3k for a paint job [BTW] this is not an issue with my svx, but with my new car 93 Alfa Romeo ].
-Pavan
Old 04-01-2006, 12:19 PM
pavanbabut's Avatar
Here are some pics -
-Top-
-Pavan
Old 04-01-2006, 02:57 PM
1000 - 2000 grit wet sandpaper with plenty of soapy water and be careful
-Bill
This is BettAr
Old 04-01-2006, 03:21 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
You're only supposed to sand it down down a little bit right? So there's still some clearcoat left..? I mean wouldn't it rust if you scrub down to the paint?
Brian
Old 04-01-2006, 03:31 PM
SVXRide's Avatar
Danny is right, adding a little dish soap to your water will help the sanded off material float away easier. Use a good sanding block and take your time. You only want to sand off the clearcoat and not sand down into the base color coat (you'll only get rust if you sand down to bare metal).
-Bill
Old 04-01-2006, 03:34 PM
But if the rust is deep, you should go all the way Pav, till you reach the bare metal... or else it won't be any good.
Old 04-01-2006, 04:00 PM
pavanbabut's Avatar
How come the rust is coming in the way? I am supposed to sand off only the oxidation coat right? untill i see the oxidised layer going off from the paint. Right?? i will keep on sanding slowly and smoothly over that region with soap water on it constantly untill I see the clear paint. first with 1000 and then 2000. Correct me if I am wrong.
-Pavan
Old 04-01-2006, 04:49 PM
The rusting is generated from the metal below the Bondo/Paint/Lacquer. You must go all the way
