Old 03-30-2006, 04:21 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
forged internals stock?
Is it true that the svx has forged steel crank and rods and forged aluminum pistons stock?
[SIGPIC][/SIGPIC]
Old 03-30-2006, 04:22 PM
yes...
tom
Old 03-30-2006, 04:27 PM
jman050's Avatar
Its a Classic!
wow thats impressive. I thought what I was reading was just BS.
[SIGPIC][/SIGPIC]
Old 03-30-2006, 04:31 PM
the eg33 is really a top of the line motor. too bad it never got much attention with FI from FHI.
Old 03-30-2006, 04:34 PM
jman050's Avatar
Its a Classic!
I know the rods and the pistons usually go well after the bearings or headgaskets. But has anyone tested the hp limits of the stock rods/pistons without a stupid mistake (detonation/nitrous below 3k)
[SIGPIC][/SIGPIC]
Old 03-30-2006, 04:36 PM
Originally Posted by TomsSVX
yes...
tom
Except the pistons. They are a pressure casting. Good quality though.
Old 03-30-2006, 04:44 PM
minor detail
Old 03-30-2006, 04:47 PM
SomethingElse's Avatar
word words wording
Spray?
I think i read a 75 shot of nos wont hurt the eg33 (due to its forged guts) at all. id prolly put a new oil pump on her first...is that accurate?
Eric
Old 03-30-2006, 04:48 PM
jman050's Avatar
Its a Classic!
Has anyone ruined a piston or rod because of power alone? I read that a few were running 150+ shots no2 and didnt have any problems until detonation or they sprayed too early.
[SIGPIC][/SIGPIC]
Old 03-30-2006, 07:34 PM
mbtoloczko's Avatar
sans SVX
If you keep the afr on the rich side (but not too rich), you'll be fine. However forged ≠ indestructible. If the motor runs lean on a nitrous shot and detonates hard, the motor will be history regardless of the forged crank, forged rods, and pressure cast pistons.
Mychailo
Visit my locker
Old 03-30-2006, 09:13 PM
THAWA
Most (read: all EJ's) Subaru engines have a forged crank and rods.
