View Poll Results: Do you jack on the rear differential?
Yes I do 23 62.16%
No I don't (please specify where) 14 37.84%
Voters: 37. You may not vote on this poll
Old 03-17-2006, 03:29 PM
Jacking up the SVX
When you jack up the back tire(s) do you jack on the rear differential or elsewhere?
Old 03-17-2006, 03:39 PM
I voted for the diff, but if I'm just doing one side, or using a small jack, I'll use the subframe mount just in front of the rear tire.
Old 03-17-2006, 03:49 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
I am guilty of doing this.
It is not the best way to jack up an independent rear. The rear diff was not intended to support the weight of the car. A solid axle rear is designed to though.
The "best" place it the jack point on the car. That is was the factory recommends, but then were do you put the jack stands
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 03-17-2006, 04:22 PM
Manarius's Avatar
Manarius Manarius is offline
I jack up my Legacy on the rear diff and put the jack stands under the sway-bar mounts.
-Jason
-Obi Wan Kenobi
Old 03-17-2006, 04:56 PM
immortal_suby's Avatar
Thread Killah
If I'm only jacking up one side I put the stand where the rear subframe mounts in front of the rear tire and the stand justin front of it on the solid flat point.
If I'm jacking up the whole rear end I use the differential.
Locker Link
2015 BRZ Limited 6MT
Old 03-17-2006, 05:58 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Jacking Positions
I use the jacking postions indicated in the Owners Manual.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 03-17-2006, 06:47 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
It says in the Chilton manual is says its ok. Most of the time when the SVX comes off the ground its with a lift.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 03-17-2006, 07:13 PM
JohnU JohnU is offline
I always thought the rear diff would be a bad spot until I bought the Service Manual. It specifies the rear diff, so that is what I use.
Old 03-17-2006, 07:58 PM
n00b on demand's Avatar
I have a really dumb question. I wanted to use the subframe to jack up the front of the car but the handle on my jack isn't long enough...keeps hitting the front bumper and it wont raise it. What are the suitable jacking points for jacking the front? Pics?
Old 03-17-2006, 08:12 PM
berger's Avatar
berger berger is offline
Send a message via ICQ to berger
i think i used the front side jack points and rear points when i riased mine last month,
all 4 wheels off the ground, made the car look pretty cool
wired up some lights underneath
Old 03-17-2006, 08:37 PM
you can always use tow hooks to jack it up... I use the rear diff and front Subframe
Old 03-17-2006, 09:59 PM
NapaBavarian's Avatar
Good morning!
I thought you were gonna go with 12 inches of lift and 36 inch tires
.Karl.
Old 03-17-2006, 10:37 PM
Lee
This is what I do too.
Old 03-17-2006, 11:16 PM
Depends on what I'm doing.
Swapping wheels I go from the side.
Things not wheel related, I have ramps. (:
Old 03-18-2006, 12:23 AM
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
that was my first thought as well
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
