Old 03-03-2006, 05:50 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Question about 4.44 tranny and Valve Body
***UPDATE*** I had posted the results of a Level 10 valve body (PTS Hydrosystem they call it) in another thread. The thread is here-->
http://www.subaru-svx.net/forum/show...ght=valve+body
For those of you that have swapped out your stock transmission for a 4.44 transmission, I have a question. When this swap is done, do you retain your stock valve body or the valve body of the car that had the 4.44 tranny? Are they one in the same?
I'm asking because I want to know if I can swap the valve body out of my Outback Sport into the SVX since they both have 4.44 trannies. (The 1997 Outback does have a 4.44 right? **Looks around**) There is a sound reason for this but I'll post it up only if needed. Thanks for any input.
Kevin Thomas
***R.I.P***
Old 03-03-2006, 06:20 PM
So far we have left the 4.44 valve bodys in the 4.44s in the swaps that I know of...
The Outback Sport has a 2.2, as you kinow, but if you have a special valve body it should bolt up.
There are rumors of special, non level 10 valve bodys, but as far as I know I have never held one in my hand.
Old 03-03-2006, 08:11 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally Posted by svxfiles
There are rumors of special, non level 10 valve bodies, but as far as I know I have never held one in my hand.
ah, but you know they're out there...probably within arm's reach
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-04-2006, 09:24 AM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Yes, this is what I needed to know. I'm wondering if the SVX can achieve 200+ torque in between shifts with the valve body upgrade.
Kevin Thomas
***R.I.P***
Old 03-06-2006, 05:28 PM
Kev a bit of work on the valve body, in the area of the accumulators can help the changes. The SVX boasted that the gear changes were undetectable, and a lot of work went in to achieving this. The accumulators soften the application of the clutches and band, and flow restrictions slow their application.
But it is the Tcu that calls the shots, it controls the engine torque and the line pressure, during the changes. So the changes will always be slower than you want. In the past I have suggested that one of the other Subaru Tcu be tried to see if the programing of the change is different. I would suggest that the TCU from one of the smaller capacity cars, like the 1800 auto, as these have less power, the change would be faster with less torque control. So it would be worth trying.
Old 03-06-2006, 07:37 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Harvey,
Excellent idea! Are you basically saying that I should use a TCU of a 4.44 geared car since I have a 4.44 tranny? If so, that makes all the sense in the world. No-one here has tried this? Nice!
After reading your post a few minutes ago, I went into my garage and scrambled into one of my parts bins. I found a 1998 DOHC 2.5RS TCU that I tested with the DOHC ECU in my 2.2ltr Outback Sport. As far as I know, the 1998 2.5RS had a 4.44 tranny (In auto trim).
I hope I have the TCU for the auto and not the manual tranny. Here are the numbers on it---->
31711 AD800
A64-000 DIF 7321
Here are a couple of pics.
I will test this out with your blessing tomorrow. What do you think? Also, is the TCU for the SVX located underneath the steering column? My SVX has drained its battery for the umpteenth time (I gotta find the culprit). I'll take my battery out to recharge it and get it in the garage for the TCU install tomorrow. Let me know what you think. Thanks!
Kevin Thomas
***R.I.P***
Old 03-06-2006, 08:23 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
subscribe!
Old 03-07-2006, 09:11 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
subscribe
Old 03-07-2006, 10:47 AM
Harvey,
31711 AD800
A64-000 DIF 7321
Kevin,
The TCU has to be for the auto, as the manual doesn't have a TCU...
The Outback Sport, I believe, has 4.11 gears....
Mid year 98 is when the auto trannys changed, I'm not sure if the TCU's changed too....but it shouldn't hurt anything to try it.
The SVX's TCU is mounted to the ECU right above your feet while driving.
I'd be interested if it made a difference or not....
Old 03-07-2006, 11:03 AM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Originally Posted by huck369
Kevin,
Huck, thanks for pointing out the obvious. I laughed a bit when I read my question about a manual trannied TCU (Oxymoron).
With this being said, I called Xotic Motorsports to see if their dyno is fixed. I left a message with them to call me back (it's between 12p-1p so they are probably eating lunch). If I can squeeze in for a dyno session tomorrow, I'll try to take off work tomorrow. If I can take off, I'll test change the TCUs tonight to see if there is a difference and to time how quickly I can change them out (which shoudn't take long at all but I always do a test install/uninstall). I'll keep you updated. I didn't expect this thread to take a turn in this direction. I'm interested myself.
*Subscribe*
Oh BTW: I just realized something. I have the Bomz pulley on the car. So maybe I can swap pulleys as well and do a test run of before and after pulley install. Neato! That is for another thread though.
Kevin Thomas
***R.I.P***
Old 03-07-2006, 11:13 AM
No Problem Kevin....
I overlook th eobvious all the time....so you're not alone
I'm looking forward to your dyno figures....
Old 03-07-2006, 02:30 PM
TCU change.
Kevin, what I meant is that as the 1800 engine has less power than the SVX, the torque control and the time for the change to take place, would be shorter, as they don't have the power to waste, like the SVX, that has plenty. So they can waste some in pursuit of a smooth change.
It would seem logically to me that the programing of the smaller cars change would be faster.
Ps Yes I can confirm that the manual does not have a TCU.
Old 03-08-2006, 10:53 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Oh Ya, I'm Subsribe'n
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 03-08-2006, 01:19 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
I have called Xotic Motorsports several times the past few days and no-one is answering the phone. I left a message twice for them to call me so I can set something up.
I just sent them an email/PM from Nasioc.
Kevin Thomas
***R.I.P***
Old 03-08-2006, 01:47 PM
As often as you go there, I figure you should have a key to the place by now.
*subscribe*
