Click..Click..Click.... AHHHHH
Ok... I know its like so hard to diagnose a sound issue without hearing the car, but as a matter of principle, I always post here before dropping my car off at the service dept. Here's the deal...
I have a 'clicking' sound... it sounds EXACTLY like a card in bicycle spokes... if you can imagine that. It comes from the engine bay. It is only heard when accelerating. It varys with engine speed, not road speed. You can only hear it when the car is under load... for example, you cant hear it when the car is in park and you're revving it, but it is VERY loud when you're in drive. Again, it varys with Engine speed, not road speed. -Mike (single handedly supporting the service department at Lancaster County Motors) |
Does it sound different than normal when starting? What you're describing may be a cracked flexplate (flywheel.)
*crossing my fingers for you that it is something cheaper* Beav |
-Mike |
I should probably mention its been doing this for at least 4 or so months... I'ts just come to my immediate attention now that the weather is nice enough for window down driving... Also, the resonator kinda masked it before.
-Mike |
Is it a valve lifter noise? Does it go away or change whenthe engine gets hot? Did you you stick your head in by the negine and listen?
Loaded or unloaded will have no effect on the lifters.
Beav |
It has the same volume no matter the engine temp...
Beav, I read in the yahoo post archives that someone had a similar noise, and it was a cracked flexplate... is this a possability? -Mike |
-Mike |
I changed the oil this morning... just to make sure... checked all the fluids etc. If i'm really careful with my revving, I can make it make the noise in park. It gets somewhat loud @ around 2200RPMs. I had my roommate rev the engine while i stuck my head around in the engine bay and under the car... Sounds like its from the rear of the engine... down low... I can hear it better under the car than in the engine bay.
-Mike |
Oh, I also stopped by the local Subaru dealer... the tech listened to it... but, he really had no idea... I ran your flex plate idea by him... he said 'could be... but ive never seen that before'
-Mike |
I actually had a problem with one of my heat shields rubbing on the drive shaft. You might check that out. (Trying to suggest the cheapest alternative).
There's really no way to tell for sure unless you can find someone with a flexible optical scope (borescope.) Next best bet would be a reputable tranny shop that has seen/heard a few before. I'd rather you took the car in to someone you trust and just tell them you're concerned about the sound it's making, not what you think it might be. Sometimes that throws them off-track, plus you won't tip your hand if they try to come back with some hogwash. Beav |
-Mike |
-Mike |
With that said, I know how much you like to take pictures of your car. Just don't take any in an open field . . . with tall grass. Otherwise, the "ticking" you'll hear will be the cooling of hot metal. That is, after your car begins to cool from the flames.
