ECU Tune Stage 2
Besides the Z32 MAF what else is needed to make the Stage 2 chip worth it, short of throwing NOS or a turbo on.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
Probably cams, plus exhaust, plus intake mods, (filter, maybe snorkus replacement). All of those working together would increase airflow beyond the range of the OEM MAF, based on Mychailo's monitored results, especially with a 5MT allowing higher shift points.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Exhaust and Intake are in the plans. Where do we get cams at?
First lowering springs, now cams... you're a one stop shop... uh shop.
Stage 2 is a MUST have to reach over 250 hp, the MAF will max out unless you get it. I think the SVX's potential is finally going to be realized now.
1992 Midnight Black LS-L - Sold 3/3/06 1991 Toyota MR2 - Sold 11/27/07 1992 BMW 325i - Tokicko Suspension |
What about a manual transmission?
I've read about some guys installing an Impreza FPR in their SVX. Would this also help augment the Stage 2 chip?
Need to be careful with increased fuel pressure with the Stage 2 chip. Can lead to idle hunting problems. Stage 2 v 4 was set up too rich at idle, and users experienced hunting idle and stalling. In putting an adjustable FPR on my car, Tom Johnson initially set the fuel pressure at higher than stock, and experienced a similar idle instability. So, I think I will keep it at stock pressure normally for convenience, but maybe raise it when I really want optimal engine performance at high revs. A long way of saying that the adjustable fpr may be a better choice than the Impreze fpr.
According to the ECUTune web site, the 2v5 chip works fine with the Imprezza fpr....
-Bill
After we have reset my fpr to stock pressure, we'll know if that statement is correct, depending on what happens to the idle stability.
Dropping the pressure from 42 psi w/o vaccum the idle to 37 the idle was restored and strange hunting stopped. I would still like to drop it a little more to see if it would help the stalling problem that comes with the 5 speed install. Anyway, I would highly suggest using an adjustable FPR rather than the imprezza.
Tom |
Thats what I thought as well but the car runs great at ~37psi. I may try to bump it to 40 to see if we can egt away with that.
Tom |
Where can I find one of these adjustable FPR?
Thread Tools | |
Display Modes | Rate This Thread |
