Old 12-23-2005, 12:53 PM
chris92svxlsl's Avatar
chris92svxlsl chris92svxlsl is offline
The best Damn Lance Corporal
Send a message via AIM to chris92svxlsl
What should my svx idle at
What do most svx's idle at ? My svx when i start it up jumps to 1250 then drops and evens out to around 500 is this normal? Also I havent started the car in two months because i've been away in the military, I have already had a bunch of stuff replaced such as the timing belt,spark plugs, water pump, pulleys belts, all the gaskets in the motor and had the car switched to synthetic mobil1 10w30. So is this low idle a good or bad thing. My other car idles at 750rpm (lexus rx330) but thats a newer car and has way too many computer crap on it for me to understand. Please help
"wow how much money did it cost for you to do that to your windows, thats some pretty custom $h!t"
Old 12-23-2005, 12:57 PM
That sounds about right. Are you having any problems with it that low? If not, I would leave it alone. These engines usually idle so nicely that you sometimes don't even know they are running.
Old 12-23-2005, 01:14 PM
The manual says 600 +/- 100 RPM. How long does it take the engine to reach that RPM?
Old 12-23-2005, 01:49 PM
idling svx
It only takes about 15 seconds to get there. just finished installing radiator that i got off ebay from kinetiq systems- its steaming- wont be buying anything from him anymore
Old 12-23-2005, 01:56 PM
Kinetic is here as Mike aka Green1995SVX
Does the engine ever stall? Has the throttlebody ever been cleaned?
Old 12-23-2005, 02:00 PM
What do you mean by "its steaming" ?
Old 12-23-2005, 02:06 PM
The radiator emits antifreeze vapors on the underside middle portion , where the metal is clamped onto the plastic. I let the car idle outside for an hour since it hadnt been started in two months and once the coolant warmed up steam came out of the radiator i dont think the seal is good on the plastic part of the radiator, no cracks just not a good seal prob any suggestions
Old 12-23-2005, 02:52 PM
I think I would carefully run the car around the block and see what happens. If you find a leak, I would let him know about it so he can make good on it.
