Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 12-05-2005, 07:04 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
stage 2V5 questions
I searched and It doesnt say on the website but does the stage 2v5 raise the RPM limit to 7400 like the 1v5 does?
[SIGPIC][/SIGPIC]
Old 12-05-2005, 08:45 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I believe that all of ECUTune's SVX chips have this feature - I was under the impression that the rpm limit was only raised to 7000 rpms....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-05-2005, 09:03 AM
jman050's Avatar
Its a Classic!
I had thought it was 7000 to but when i checked the ECUtune website it said 7400 for the old stage one so im not sure.
[SIGPIC][/SIGPIC]
Old 12-05-2005, 10:04 AM
SVXRide's Avatar
You know, I think you're right...it really only applies to the 5 or 6 spd folks, as the 4HEAT kicks you out at 6500..
-Bill
Old 12-05-2005, 01:01 PM
Mine would cut out at an indicated 7200RPM at best due to the MAF issue. I still only have the Stage 1V3.
Old 12-05-2005, 02:38 PM
jman050's Avatar
Its a Classic!
is there anyone that can verify that the 2v5 with MAF allows the rev limit to be raised?
[SIGPIC][/SIGPIC]
Old 12-05-2005, 03:02 PM
I wish I could. I can't justify the expense at the moment.
Old 12-05-2005, 03:15 PM
7400 rpm is right... I tend to run it to 7200 or so in 1st gear when I dragged the car... unless you upgrade other parts on the car running at that high rpm is mostly useless
Old 12-05-2005, 04:34 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
ditto....i reached 6950rpms on the dyno so its been street and dyno varified..
phil
~Phil
Display Modes Rate This Thread
Rate This Thread:
