Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 12-02-2005, 06:59 AM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
ECUTUNE on eBay!
I saw EcuTune stages one and two on ebay by a seller named ECUTUNE, so I hope its authentic. But now its even easier to buy EcuTune.
http://cgi.ebay.com/ebaymotors/ECUtu...18823911QQrdZ1
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 12-02-2005, 07:15 AM
shotgunslade's Avatar
You want Stage 2v5 anyway. Has the idle bug fixed. Very nicely, I might add.
Old 12-02-2005, 08:21 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
That's LAN's auction so everything is on the up-and-up. He's had his stuff on ebay for over a year now.
-Chike
2006 Steel Gray WRX TR (sold)
