Old 12-01-2005, 05:41 AM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
this is very intresting. im going to read up at the local library so i know what your talking about.
Old 12-01-2005, 03:03 PM
VTsuby
I did some minor porting today and bumped the head up to about 255cfm at .450". The pitot still isn't working and I'm not going to get crazy with it until I can see what exactly the air is doing in there. So all I have done so far is fill some of the bottom of the port, enlarge the radius on shortside turn, alittle work on the guide and cleaned the port up some. It still has a long way to go.
Old 12-07-2005, 07:06 PM
NeedForSpeed NeedForSpeed is offline
Good work!
Could you map the stock port flow at various lifts and let us at what lift the stock ports have the highest flow?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 12-11-2005, 10:58 AM
longassname's Avatar
Just some dude.
allright you guys with heads all over the place.......... would somebody please cc the head?
Old 12-14-2005, 09:58 AM
VTsuby
About .425"
Old 12-14-2005, 10:28 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
About .425"
That would be a linear measurement, not a volume measurement
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-14-2005, 12:24 PM
Just some dude.
What about you Bill? You said you have a head off. Come on now.
Old 12-14-2005, 12:47 PM
VTsuby
About 52cc chamber volume
.425" was where peak flow on the port I've been was stock
Old 12-14-2005, 03:29 PM
Thanks for doing the measurment, that would make it 7:1,with the 2.2 turbo pistons.
Old 12-14-2005, 04:08 PM
Just some dude.
how about are we talking about?
Old 12-14-2005, 07:27 PM
How close is the 52cc? + or - what. How did you do it?
Sorry about the doubts, just want to be certain.
Old 12-19-2005, 05:25 PM
Just some dude.
The measurement seems about right. I've done it myself now and came up with 51cc.
Old 01-25-2006, 09:09 PM
mbtoloczko's Avatar
sans SVX
Can you make a table showing flow vs intake valve lift at several values between 0.280" and 0.450"?
Mychailo
Visit my locker
Old 01-25-2006, 09:14 PM
mbtoloczko's Avatar
sans SVX
I finally got the heads rigged up on the flow bench today. We have had issues calibrating the software for the bench but for an initial test I lifted the valves to .450" and saw 235cfm. ...
Were the springs still installed when you lifted the (intake?) valves to 0.450"?
Mychailo
Visit my locker
Old 01-26-2006, 11:40 PM
Thanks for the info.
Please post the peak flow and and lift of the EXHAUST port as soon as you get there. Good work!
