Fixing things? How many cars with 150K miles have you had. Of course he's going to be fixing things once in a while. At least he didn t get a GM or something. At 3.3L and only 230 hp these engines are barely breathing hard. Solid as a sledge hammer if you do routine maintenance. Transmission? If you do have to replace it (and there are folks out there with 100+K who haven't), upgrade a couple of years if you can. I have heard of newer trannies going out, but not nearly as often as the '92's. Basically, if you treat it like any other car that you'd like to last forever, oil changes once in a while and stuff, you'll be one happy camper.
Steve '95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten) '02 Outback LLBean, 56K '02 Black Sapphire Volvo V40, 133K - "Shadowfax" '06 Triumph Tiger, 19K '99 Suzuki DR350SE, 8.5K - "Geezer Killer" <*}}}}>< ~ ~ ~ ~ ~ ~ ~ ><{{{{*> |
What I am trying to do is tell him things to keep a look out for and what to have checked since it is a new car with 150k miles on it, that's all.
Check out this thread:
http://www.subaru-svx.net/forum/show...&threadid=2758 I got a great deal also. $4,400 for a Green 1995L with the only found problem (by a highly respected Subaru dealer) being a leaking valve cover gasket. Otherwise, the car is in excellent mechanical/cosmetic shape. I picked it up Sunday, had it detailed yesterday and will have the valve cover fixed on Thursday. |
Some people have had reliability issues with their SVXs, but I think that's due to the way the cars were treated. Every SVX I've seen that has been treated well has served its owners well.
-Mike |
his only real worry should be the tranny.
the tranny is the biggest problem because it is so expensive to repair. basically immediately go out and slap on an aftermarket tranny cooler and you will be sitting pretty. if you get the occassional bearing or warped rotor...big deal. price you pay for a heavy awd sports car. in my book the price is not too shabby!
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
SVX find update....
Hey gang...SVXTc has valid points! However....owning Subies for the past 15 years, and researching the SVX before I decided to look for one, I was pretty much aware of the shortcomings and knew what to look for. I bought the car from a 56 year old woman who, shall we say, was" full of religon". A stack of reciepts for all the maintenance and repair work came with it (mostly from Flatirons Subaru in Boulder).
I have known Mike at Wings Stuff in Denver for years, and took it down there monday so they could go over it and tell me exactly what I have. The only prolems found- rear wheel bearings (which I suspected when I took my test drive), and leaky valve cover gaskets (imagine that!). We replaced the wheel bearings, serviced the tranny and the differential. On the way home I stopped by Merrill Axel and Wheel in Lakewood and had all four balanced, and a alignment. Brakes with new rotors 8k ago, battery (770CCA) 3 mos. ago, new alternator (Subaru) 2 mos. ago, timing belts at 106k...and the list goes on.... Bottom Line- I'm still smiling!! One annoying thing...an erratic fuel guage! Can you guys give me some insight on what seems to be a common problem??? Thanks in advance.... The meet in Indiana sounds great and I plan to attend. I sent Larry a email for info.. Thanks to all of you for your comments and suggestions! Tom |
Re: SVX find update....
[One annoying thing...an erratic fuel guage! Can you guys give me some insight on what seems to be a common problem??? Thanks in advance....
Erratic? When pegged on empty, you've got a quarter tank of fuel left. All SVXes have this feature at no extra charge. Check Beav's "heavy float" theory for details. Ron.
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
I was just thinking about that. Maybe a couple brass carburetor floats would do the trick. I'll have to do some 'creative' digging...
Beav |
congatulations on your find. I am pearlie with envy. My son has had a 92 since Christmas and so far we are only dealing with annoyances. Slight leak of ATF and therefore some smoking. But nonetheless we all love the car.
Thank U RUUJ
I bought my 92 pearlie in Dec of 2001 sight unseen on ebay because I fell in love with the idea of a "sports car for under 6000.00" I stumbled onto the yahoo site and larryiii pointed me here for a little more Tech minded and organized format. I started to panic everytime I heard a noise or felt the road bump a little after reading some of the horror stories. Then I started to do a little math, and the numbers were telling me that more people with the car were probabily driving like "normal" people and not having the all of the problems that were being reported here. I've got some minor problems with the car, mostly cosmetic now that I think about it, but the tranny seems to be fine (after a fluid change) and the ride is smooth on a good road. I love the pick-up and the handling. And after your post. I feel better again.
Thank you!
Mitch Hansen
"uncamitzi" This is a Dark Ride 92 Teal SVX LS-L 128K tranny swap with 4.11's Well.. my days of not taking you seriously have certainly come to a middle . |
#30
it is easy to freak yourself out......
you will learn to take it easy while still paying attention to the car. the only think i still get freaked out about is tranny related or leaking fluid related stuff. everything is just routine.
