Old 09-23-2005, 09:42 AM
Someone caught a pic of me driving w/ Chike in the car at the Subaru Callenge. My rears are at 1/2" lower than stock and my front is 1" off from stock but I still have 2"+ to go lower in the front?? Also, check out my body roll pic, seems like you are getting a bit more than I
http://www.subaru-svx.net/forum/show...&page=32&pp=15
post #472
Old 09-23-2005, 10:10 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
post #472
Here ya go:
2006 Steel Gray WRX TR (sold)
Old 09-23-2005, 10:38 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
post #472
No Tom, David is just going faster then you!
Old 09-23-2005, 10:40 AM
Chiketkd's Avatar
Hey, watch your mouth....I resemble that remark!
-Chike
Old 09-23-2005, 11:32 AM
Originally Posted by SSSVX
Did you get your SVX from US had it converted? You have auto seatbelt and all 92 canadian cars have auto seatbelt as well?
Mine is Canadian. I get weight savings from the lack of an alarm...and no I don't have heated seats.
The seatbelts followed the same pattern as the US SVX's
Old 09-23-2005, 11:36 AM
Yeah, that's it...plus I'm going to have to assume my tires are a little bit stickier than yours.
Old 09-23-2005, 11:46 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Think bigger front sway bar!! (and larger rear bar, while you're at it...)
-Bill
Look, Ma.....just the right amount of body lean
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-23-2005, 12:10 PM
I still need bushings
Old 09-23-2005, 12:15 PM
benebob's Avatar
You still got plenty of lean there Bill BUT in realilty too little lean will slow you down just as much as not enough. You need some give there otherwise it all goes to the tire and tires are not real forgiving when they go. In a perfect world in which you can put on 11 inch wide rims and wheels it isn't an issue but in the real world its better for the body to give then for the tires to go. Look how easy it is to put formula Vs and Fords into a spin. Much of that has to do with lack of roll.
Old 09-23-2005, 01:21 PM
SVXRide's Avatar
Ben,
Good point...I think "Bill-Stock" is at the "just enough" lean point now
-Bill
p.s. putting GCs on it would probably put it over the top, which means I'd have to back off on the size of the bars to balance the overall loading on each corner. I've got the calculations around here somewhere, but I seem to remember that my "Mychailo springs/custom sway bar/Koni" mix provides around the same wheel loading as the "GC/stock sway bar/Koni" mix that Porter was running (maybe a little stiffer?). Maybe Mychailo can help out here, as he did the calculations
Old 09-23-2005, 01:30 PM
Chiketkd's Avatar
Thumbs up
Originally Posted by SVXRide
Ben,
-Bill
"Bill-Stock" is at the super cool point if you ask me! I just love that pic!!!
-Chike
