View Poll Results: Experince with your 5MT
Runs great 100% perfect 4 33.33%
Runs well but not 100% perfect 8 66.67%
Used to run well, but was dead after sometime 0 0%
Voters: 12. You may not vote on this poll
Old 09-15-2005, 01:30 PM
pavanbabut's Avatar
Question How many 5MTs on the n/w & experiences?
Hi all,
I just want to have an idea on how many 5MTs were installed into our cars. Their condition and owner's experiences with them.
I made this poll public, so that others and future 5MT owners can look at the present 5MT owners.
You can give/explain your experiences by posting too...
Happy voting
Update: Please also indicate whether the installtion is done professionally or by yourself...
thanks,
-Pavan.
Old 09-15-2005, 09:06 PM
well not 100% but works well. My only problem is, the trans couldn't keep up with my drag shifts and I burned out my second gear synchos. Besides that, doesn't skip a beat
Old 09-15-2005, 10:00 PM
svxsubaru1's Avatar
I have about 7,000 miles on mine, spec stage 3 first gen legacy 5spd AWD either 220,000, or 125,000 miles when instaled. Very abusive to it, and it will gring if you dont shift perfect into 2,3, so it definitley went down hill, but its still perfectley drivable.
Old 09-15-2005, 11:01 PM
mbtoloczko's Avatar
sans SVX
My 5MT is in perfect condition, but I started out with essentially a brand new tranny, and then installed STi RA gears. Add a top quality installation job, and with the exception of low speed jerkiness caused by driveline slop (probably in the rear subframe), the tranny works perfectly.
Mychailo
Visit my locker
Old 09-16-2005, 04:18 AM
gsodonis's Avatar
gsodonis gsodonis is offline
Near perfect
My 5MT is near perfect. I bought it about a year ago with 92K on the ODO and now have 113K; I drive it every day. As with most SVXen, my baby needs little things here and there, but nothing that keeps her parked. None of my friends and associates believe that the 5MT wasn't standard; that's how well the conversion was done.
Old 09-16-2005, 09:35 AM
pavanbabut's Avatar
Hi gsodonis,
So you bought your car with 5MT installed in it? Do you any idea if the installation is done professionally or by the owner itself?
-Pavan.
Old 09-16-2005, 09:46 AM
gsodonis's Avatar
Subaru tech
The previous owner had a factory trained Subaru technician that opened up his own shop do all of the post-warranty maintenance on the car. Once the auto tranny failed, they had him do the 5MT conversion. I've since made some slight improvements along the way, but the installation was at least 98% spot on.
Old 09-16-2005, 04:15 PM
UT_SVX UT_SVX is offline
livin in AZ
I did the install with a buddy, as far as the manual it is near perfect. I need to get a new exhaust because my tranny mount rubs slightly, and need the STi RA gears(just for a little more confidence in the tranny). I miss the top end speeds for freeway cruising, but it probably saves me on speeding tickets.
darren
"Stand up Strong, Feel the Pain! Till the Angels Sing"
Social Distortion
1992 LS-L Pearl White :Optima Red Top, Motorsports Warehouse drop springs and swaybar bushings, Race Concepts slotted and dimpled rotors ,SS brake lines,semi-metalic brake pads, 4.11 5 speed, STi short shifter and tranny mount, Exedy sport clutch, Kartboy shifter bushings, intake silencer removed, ECU Tune Stage 1 v4
Old 09-17-2005, 11:01 AM
AvPPoW AvPPoW is offline
Uh, me and my dad did it. It worked out pretty good. Still some quirks to work out
Old 09-19-2005, 04:36 PM
Getting close to 2 years on the 5MT for me. No new issues since installing it. I'm also looking to eliminate the driveline slop.
