Old 08-04-2005, 07:09 PM
Subafreak's Avatar
Superbeast
Ride hight?
OK, who has the right specs and measuring points for the ride hight?
I've looked in three different places and found three different specs. It looks like the measuring points are from the center of the wheel to the bottom of the wheel wheel arch.
Right now I measure 14" in the front and 12 1/2" in the rear. So how low am I really from "stock"?
Old 08-04-2005, 07:24 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I'll check the alignment machine tomorrow morning, it should have them listed.
Old 08-04-2005, 08:01 PM
Subafreak's Avatar
Superbeast
Yeah, I looked on Alldata, a Motor manual, and in Chilton manual and got different numbers from each one.
Old 08-04-2005, 08:11 PM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
I have the factory manuals,I'll check them tomorrow and let ya know what they say.....
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
Old 08-04-2005, 08:15 PM
Subafreak's Avatar
Superbeast
Yeah, lemme know what you guys find. I think I would trust the factory manule the most.
And on the same note, what are some of you other guys running in ride hight? Stock and modded?
Old 08-04-2005, 09:21 PM
I will let u know on Tuesday
Old 08-04-2005, 10:35 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Jesse,
check with Mychailo - I gave him my "stock" ride height and "Bill-stock" ride height way back when and I'm sure he's got it in a database somewhere.....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-05-2005, 12:24 AM
mbtoloczko's Avatar
sans SVX
Originally Posted by SVXRide
Jesse,
-Bill
Jesse, I've got real-world numbers for the LS-L (Bill's car, heavier) and the L AWD (my car, lighter), but they are in my notes in my briefcase (actually its a computer bag) at work. I'll let you know on Fri. morning if you are interested.
Mychailo
Visit my locker
Old 08-05-2005, 01:04 AM
KCROGUEDOG
i dont get how u are measuring but i did mine today and from ground to the high point in the arch of the wheel im 25 inch in front and 25 1/2 in rear. i want to raise the back 1 inch or so.
Old 08-05-2005, 04:58 AM
Subafreak's Avatar
Superbeast
Your suppost to measure from the center of the wheel to the high part of the arch, that way tire size does not sque the results.
Everyone else, let's see those numbers.
Old 08-05-2005, 06:37 AM
Beav's Avatar
Not as old as Randy
Center of wheel to fender lip.
Front = 14.2 - 15.4, 15" preferred.
Rear = 12.4 - 13.6, 13.2" preferred.
Old 08-05-2005, 09:02 AM
gettin there....
Beav nailed it.....
Manual say's with luggage comp empty,and with a full tank of fuel also......
Mike....
Old 08-05-2005, 09:05 AM
KCROGUEDOG
ill post back with a better measurement. i got stock size new tires at 215 55 16 and the arch is just a inch above the tire. so im pretty low.
Old 08-05-2005, 10:18 AM
mbtoloczko's Avatar
sans SVX
My L AWD in OEM condition was:
front: 14.6"
rear: 13.25"
Mychailo
Visit my locker
Old 08-05-2005, 10:41 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
On my '96 awd L model with 2/3 tank of gas, I measured:
Front = 15.0"
Rear = 13.25"
Checked the measurements on the driver's and passenger side and they were the same.
-Chike
2006 Steel Gray WRX TR (sold)
