Old 02-07-2002, 11:14 AM
Question Dipstick
It seems that every time I open the hood, I find that the oil dipstick has crept up abut 1 inch. I push it down each time, and find it up the next time I open the hood. I don't know that it is up far enough for water or dust to get into the tube, but it still bothers me to see that it is not down tight. When I have seen others open their hoods, I have seen other dipsticks that are in the same position. I am starting to think that this is a common problem, or occurance. Does anyone else have the same thing happen, or am I over reacting. I could just ignor it and hope it goes away, but I doubt that will happen.
Old 02-07-2002, 11:24 AM
Invisible avatar
Unhappy
SVXcess (John) has the same problem & mine's beginning to pop sometimes. Could be the little O-ring wearing out.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 02-07-2002, 11:37 AM
wasions's Avatar
wasions wasions is offline
SVX Black Belt Master
Dijon vu - didn't I have that mustard before?
I think someone had an explanation and a solution for this problem somewhere (probably in Yahoo) but someone else will have to find it.
Just wait - it'll show up eventually.
Steve
'95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten)
'02 Outback LLBean, 56K
'02 Black Sapphire Volvo V40, 133K - "Shadowfax"
'06 Triumph Tiger, 19K
'99 Suzuki DR350SE, 8.5K - "Geezer Killer"
Old 02-07-2002, 11:45 AM
Yes, I noticed that there seems to be a little O ring on the dipstick. I wondered if that needed to be replaced so it might make a better seal or create more friction. I don't know if that would do it or not. I'll watch for "THE ANSWER".
Old 02-07-2002, 12:18 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
The first thing to check is that your PCV valve is operating correctly. It's a pain in the butt to get to, but, that's the first thing to check.
Otherwise, yes, it's the little o-ring on the dipstick (from experience). I busted mine trying to take it off to find an o-ring in my box-o-goodies of things in my garage. Couldn't find one. "I'm screwed" I thought. Then, I noticed that fuel line is about the same circumfrence as the o-ring. I sliced off a piece of fuel hose of the same width as the notch in the dipstick and rolled it into place. I nearly have to get into the engine bay and pry the thing out now. Working like a charm now for more than 10K miles.
Randy Johnson
Mike Davis -- at Reading VI
Old 02-07-2002, 01:38 PM
Mr. Pockets's Avatar
Moderator
Re: Dipstick
Mine does this, too. Replace the o-ring if you want. Replace the PCV valve. But the real ANSWER is to wait until spring. Mine only seems to do it in winter.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 02-07-2002, 02:32 PM
calmone
see in the winter the cold makes the o ring (probably rubber)contract a bit. similar to the hood strut situation. i've have a squeek in the front end of my infinity for about 5 years now. my mechanic said something like "well, you can spend a few hundred bucks replacing rubber parts in the front end until we get the right one, or you can throw some silicone lube on it and wait till spring. spring, ahhhhhhhhh spring. maybe we should all move to lousianna or florida, eat stone crabs or crawdads and forget this awd stuff!
Old 02-07-2002, 02:38 PM
I had the pop-up dipstick syndrome. I ordered a new one form my dealer and comes with a new o-ring. The o-ring had turned from rubber to a hard, brittle plastic from engine heat, and the dipstick handle had darkened as well.
I also ordered the o-ring to use on my old dipstick while waiting for the new one. The part number for the o-ring is 806908080 and is available separately, about a dollar.
Replacing the o-ring made a very snug seal so the dipstick stayed in place.
Old 02-07-2002, 03:02 PM
Replace the O ring -
OR we could all wait till spring, eat crabs, and spray silicone on our dipsticks.
But ---- there is another winter acomin'.
Old 02-08-2002, 09:14 PM
htyei's Avatar
htyei htyei is offline
SVX Animated Icon Guy!
Send a message via ICQ to htyei Send a message via AIM to htyei Send a message via Yahoo to htyei
replacement
25 cent 9/16 oring form orchard supply...
Dont quote me on the size. I remember buying two different ones,
one fit the other did not.
Prying out the dead pdry hard oring , was odd, It was so hard, I didnt think it was an oring....
Henry Yei
htyei@svxwrx.com
1992 Dark Teal LS-L w/o spoiler "OLIVIA"
http://www.svxwrx.com
Old 02-11-2002, 12:42 AM
249SVX 249SVX is offline
still in love with Hannah
Re: replacement
I used some electrical tape about 20,000 miles ago
silver 92 SVX-"Hannah" -R.I.P. NOV. 1991-jAN. 17, 2003
red white and blue 2000 Suzuki TL1000-r-"Bethany" This grips me more than a muddy old river or reclining Buddha.(now running Metzlers!
black 1987 Toyota MR2-"Helga" -Turbo conversion will now commence.
1996 Legacy Outback-"Gilda" white with brown trim
