Old 06-07-2005, 02:03 PM
KCROGUEDOG
half shaft install ?
well tomorrow i get to lift the svx and install my half shaft pcv valve and o2 simulator (replaces o2 so no codes are thrown). long day. any ways on the half shaft topic do i have really have to disconnect the sway bar and mess up aliginment? my chiltons book says to mark it. heres what it says in short hand. unstake and remove axle nut. disconnect sway bar link from sway bar. disconnect abs sensor bracket from strut. remove brake hose bracket bolt and bracket from strut. matchmark sway bar lever to sway bar. remove sway bar lever. (what is the sway bar lever?) loosen sway bar bracket. remove lower ball joint pinch bolt. drive out pin in shaft. seperate ball joint. pull out shaft. is there other important info i need to know? does everything sound right for those who have done this? and is there anything i mentioned that is pointless to do? tips?
Old 06-07-2005, 02:28 PM
Sounds like a few extra steps. I've never had to remove the ABS sensor or anything to do with the swaybar.
Old 06-07-2005, 02:54 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
There is a how-to.....
http://www.subaru-svx.net/photos/files/How-To/14341.doc
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-07-2005, 03:59 PM
That's right I forgot it's also in the SVXipedia
Old 06-07-2005, 05:36 PM
KCROGUEDOG
earthworm did u have the 5 spd when u did the shaft? would that make a differance? also the how to says nothing about the sway. i hope i dont need to touch it.
Old 06-07-2005, 05:40 PM
KCROGUEDOG
i like the svxpedia way sound detailed and very well put thanks for the referal. im still up for tips the more info the better. the harder u study the more u get to know.
Old 06-07-2005, 05:41 PM
It's the same thing regardless of which transmission. We swapped the axles well before putting in the tranny. We used the same axles between the 4EAT and the 5MT.
Old 06-07-2005, 05:43 PM
If there's anything missing from the article in the SVXipedia use the feedback button.
Old 06-07-2005, 05:58 PM
Word to Yo Motha
AFAIK the sway bar does not have any affect on the alignment of the car. You can even remove it completely if you so desire with no ill-affects on the alignment. Though if you do drive without it, the handling is terrible.
Collin
1995 L AWD
Locker
Old 06-07-2005, 06:27 PM
KCROGUEDOG
nice to know
Old 06-09-2005, 08:08 PM
KCROGUEDOG
install went smooth and no problems nice info. i did do something you might want to sugest on svxpedia. i removed the lower ball joint. it came out smooth to remove the 2 outside a arm bolts. i tried and tried to get them out re read and everything they wouldnt come out till the ball joint did. i had another person to hold and pull the rotor out and arm down to slide in the shaft. easy install. ty
Old 06-10-2005, 10:49 AM
That's what the feedback button is for!
