1992 Alarm questions
Hello All,
I just recently purchased a 1992 SVX and am really enjoying it. I did have it to the dealer to take care of some issues but now all is fine. The 2 problems that I’m experiencing now is 1 with the alarm system and one with the automatic drivers side seatbelt. I did search this forum and was unable to find the identical problem or question. Alarm: Seems like all was working fine before the dealer visit, and I did call them for assistance but offered no real help, here is what is not working: 1. using either remotes the drivers side door will not lock or unlock 2. using the key in the passengers door does not unlock the drivers side door 3. while inside the car locking and unlocking the doors using the passengers side door inside lock does not lock or unlock the drivers side door Otherwise everything else works as the owner manual states. Seat Belt: What is the criteria for the lap belt moving out of the way when exiting the SVX? It always works if the key is in the ON or ACC position and the driver side door is open, intermittently it will move out of the way when the key is removed and the door is opened, I was just wondering what the proper behavior should be. Any help or pointers would be appreciated. Thanks’ jr |
2 and 3: That is normal behavior. The driver's door key and lock lever also operate the passenger lock, but not vice-versa. Sounds like maybe the lock servo motor in your driver's door is bad or has a faulty connection.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
Hi and thanks for the response, using either remote I can arm and disarm the alarm, the remotes will also lock and unlock the passengers side door only.
Also is the servo motor located in the drivers side door? |
Both of these are normal. Dave |
I would doubt it's your servo motor. Your problem is in the trunk. The control box is located directly under the rear wiper in the trunk. See my locker for pics. I had the same problem with the lapbelt and spent along time diagnosing the problem. I replaced the module and everythign has been fine. I have also helped a few other members on this board with the same problem and replacing this module has worked for everyone. This will cure your lapbelt problems. And possible your unlock issues.
The control for the 92 is in the trunk? i thought it was behind the glove box.
So if the driver's door servo isn't working, it's either the servo motor or the part of the wiring unique to that motor. The problem is very likely inside that door (that's where I'd look first -- easier to access). I'd also find a wiring diagram that shows the physical location of where the wires going to the two servos split. Probably happens right behind the door lock module. At least some years (not sure if all), the door lock timer module is behind the glove box. On the 92, the security module is there too. I think the motorized seatbelt control module is always in the trunk.
