Old 05-28-2005, 05:38 PM
calisvx calisvx is offline
Exclamation need help with tranny
ok here goes i will try and make it short! first thing that happened it began to slip i believe from 1 to 2 and it felt like 3 and 4 were fine so i read a couple forums and i decided to do a brake band adjustment so i did test drove it the slip stopped and a day later i feel that the car seems to stay in lower gears more until i accelerate then it feels like it stays in 3 and now i have no 4 also i did a hard accel and it shifted fine until it reached a gear 3 to 4 ??? and the engine reved without the tranny grabbing a gear i let go and accelerated slow and it was fine ? sorry if this was long any suggestions ?
Old 05-28-2005, 08:10 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
I would loosen the band brake up by 1/2 turn and see what happens.
Also when was the tranny fluid changed last and do you have an external tranny cooler installed?
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 05-28-2005, 08:56 PM
dont know when the fluid was changed last owner said he put in new tc so i asuned it was changed i made the turn it feels better should i turn it some more?
one other thing i noticed when iam on the freeway and i let go of the gas the tach goes down to the idle position and my other car doesnt do that?
Old 05-28-2005, 11:34 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Cool
does the power light blink for 8 sec. after you start the vehicle?
Old 05-29-2005, 01:45 PM
no lights come on the power light is off i checked twice nothing fluid looks good no burning smell what should i do next? should i loosen the brake band bolt more? should i change fluid again?
Thanks for the help this happened so quickly overnight its weird.
Old 05-29-2005, 08:48 PM
SVX-FF's Avatar
I would change the fluid and see what results you get. Fluid is cheaper that a tranny.
Steve
Are you in?
My Old Locker
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 05-30-2005, 10:07 PM
iam gonna change the oil this week is there a special procedure with these cars ?and where do i buy the gaskets and filter?
Old 05-31-2005, 03:37 AM
KCROGUEDOG
i recomend the shift kit for sure. also my 97 runs to idle 2 secs after gas is completly let off.
Old 05-31-2005, 03:11 PM
hmm if all else fails what a rebuilt go for these days?
iam not giving up yet but i will try everything before i go to that
and whats the deal with the shift kit?
Old 05-31-2005, 03:21 PM
KCROGUEDOG
its only 50 bones and it splices in to the resister behind the battery to make the resistance adjustable by screw. it lets you make your shifts hard and solid or buttery smooth and not noticable. i had a high end lag at low rpms in d in 4th gear. maybe a small slip im not sure but the kit eliminated it. i keep the shifts solid and tight for no gear hunting that causes heat. it still feels good to nothing annoying. www.smallcar.com www.smallcar.com/svx/tskinstructions.htm
Old 05-31-2005, 08:57 PM
SVX-FF's Avatar
Nothing special, except some drivers , the tranny filter and gasket can be gotten at most auto parts stores. I would make sure it has a rubber gasket. Those cork ones are a little corkie
Steve
Are you in?
My Old Locker
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
