Old 05-29-2005, 01:10 PM
immortal_suby's Avatar
Thread Killah
mine - 225-45-17 falken azenis sport. Usually run about 47F/44R. Sometimes 45/40
hers - stock size kumho ecsta ASX. Usually about 42F/38R. Sometimes a little higher/lower than that but never as low as the recommended pressure.
I have had bad experience with the recommeded pressure blowing a sidewall on my 17's and bad uneven wear on stock rims. I have had great wear patterns with higher pressure. Car seems to run a lot better on the road too. Less mushy in corners. Ride is a little more bumpy though.
Locker Link
2015 BRZ Limited 6MT
Old 05-29-2005, 02:53 PM
mbtoloczko's Avatar
sans SVX
Sumitomo HTR+ 225/45-17 on 17x7.5" rims. Pretty decent grip in wet and snow. Have to run about 35f/31r to get even tire wear. Anything higher and the centers wear much faster than the edges. I'll be running Toyo Proxes 4 225/45-17 on Rota 17x8" rims by the end of summer.
Mychailo
Visit my locker
Old 05-29-2005, 03:41 PM
svxstarship svxstarship is offline
Michelin Pilot Sport. Factory Pressures. Expensive but worth it.
Old 05-29-2005, 10:09 PM
JonathanS JonathanS is offline
[QUOTE=Rotorflyr]You mean Kumho Ecsta right??
Yes, Kumho Ecsta ASX. Thanks.
Old 06-06-2005, 11:59 AM
dromano's Avatar
dromano dromano is offline
Sumitomo Srixon All Weather, very quiet, $65
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 06-08-2005, 10:23 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
On the '92 im running Michelin MXV4 Plus' 215/55 on stocks (40f/36r) and on the '95 im running Yokohama Avid V4's 225/50 on stocks (42f/38r) both sets are V speed rated and A traction rated. The Yokohama's will probably be the first to go (I can kick the back end out way to easily).
dustin
-Dustin
Old 06-08-2005, 10:54 AM
Originally Posted by svxfiles
I can spin them,
In the dry!!!
Do you have the same tires? I don't want to be able to spin them...
Old 06-08-2005, 10:57 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
He can spin them....
He also has a supercharger and 4.444 gears.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-08-2005, 11:03 AM
And I can burnout through first gear. So what? I want tires that don't spin. :P
Really though, are those super grippy?
