Old 05-14-2005, 11:07 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
How low can you run the oil before the light comes on
Just trying to get the max amount of power out of the racer. I know that by lowering the oil in the pan you actually increase your power and also your weight is saved. Just wondering how low one can go before the light would come on. Never had a light on a subie come on but I'm quite anal about keeping my oil level between the H L marks and check it weekly. I'm thinking probably about 3.5 quarts would be enough so long as it is changed often enough. Anybody wanna admit to the neglect of having their light come on and let me know how low ya were. PM is fine if you don't wanna be blasted by some. I'm sure I will be over the post.
Old 05-14-2005, 12:54 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Ben,
I was talking with Mychailo over a year ago about moding the oil pan to reduce "windage" and pressure loss during racing and his feedback and his response - after checking with his local Subie WRC guru - was that the stock pan has such a good design that no mods are really necessary. This all typed, it probably wouldn't hurt to only run 4 qts (the "LOW" mark on the dip stick is 5 qts).
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-14-2005, 02:58 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
There is a windage tray (see the big thing in between the block halves here:http://www.subaruparts.com/diag/?mod...ategory=004-A), and the pan is deep enough to keep the oil pickup covered when cornering hard. However there has to be enough oil in the engine to drain down to the pickup. There's going to be a lot of oil sitting just under the cam covers, for instance. When cornering hard ands low on oil it is still possible to have enough pressure to keep the light off but the oil can/will be severely aerated, which is probably just as bad as no oil.
I compliment you on trying to cover all the bases but, as I've said many times before, most people will be best served by saving their pennies and going to a bona-fide driving school. Not only will that put you light years ahead of the others on the track (yeah, I've got lotttts of experience with those guys) but you win more races and not abuse your equipment while doing so. Besides, it's great fun!
Old 05-14-2005, 05:06 PM
svx_commuter's Avatar
Your post really caught my attention. The oil light only comes on when the pressure is low. It is not a low oil level light. If I remember right the number is 2.1 psi. I think that racing an engine with 2.1 psi is a very quick way to wear out the engine. As Beav says all that entrained air is not good.
If I was to beat the snot out of my SVX again I owuld use Lucas oil and fuel additives. Both are made for racing to improve power, reliabilty and engine life.
The hotter the oil gets the less it lubricates as the viscosity drops. More oil in the pan gives it some time to cool off as the air passes the pan while driving. More oil in the pan has a longer retention time and the oil get cooler. The cooler oil goes to the bottom of the pan where the pump suction is. So the coooler oil goes to the pump. Less air also gets to the pump suction because the pan is deep. I think the excellent lubrication system is one reason why the SVX engine lasts a long time.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 05-14-2005, 06:23 PM
benebob's Avatar
Duely noted, I doubt I'll be at it but the other half of the racing team will be at a school next Saturday. I'd be there too but I'm on borrowed time as it is. My wife was due on Thursday. Just waiting for the ordeal to begin . Went to the school 2 years ago though and as the car gets the majority of what it needs done to make it legal for Solo 1 then I'll be going to those schools as money becomes available (blood for sale!!! Very rare type too!!!)
I definately wouldn't go down so far as to hurt the engine majorly, just down far enough so as to keep everything as low as possible. An oil cooler is in the plans in the near future as is 5w 30 mobil syn (best of the cheaper). Lower oil is a time tested method by most in solo racing and really doesn't affect most engines. I know all to well that a boxer engine is different though. Just trying to get an idea on how low I can go safely
As for Lucas products commuter, I'm not overly convinced. I've VERY sceptical of products that don't have indie lab results backing them up (Lucas, Purple Power, Redline, etc...). IMO they may be the bomb but I prefer time tested lab results to back it up not what the maker claims and since I don't have the money to invest in the lab work I rely on what I can find. There just isn't anything out there on these products that I've come across.
As for the light, it comes on that low huh for o.p.? I guess I'm not suprised as the trans temp light comes on just below the temp in which most tranny fluids will catch fire.
Old 05-14-2005, 08:27 PM
immortal_suby's Avatar
Thread Killah
I hope you have your bags packed!
Locker Link
2015 BRZ Limited 6MT
Old 05-14-2005, 08:32 PM
benebob's Avatar
. What bags??? How's you're little one doing? Driving yet?
Old 05-14-2005, 08:38 PM
Thread Killah
Doing great! I have to get a steering wheel for his carseat!
Locker Link
Old 05-15-2005, 06:31 AM
Ben,
My advise is to run at least 5 quarts in it (up to the Low Mark), as the g's experienced in auto-x, will slosh it all to one side and could cause the pick up to suck in air....which is a good way to end up with a block like Melis's ER27....not something I'd want....most race cars actually hold MORE oil than a street car, since they're so demanding on the engines....that's a pound or two I'd keep in the pan...hey that's about as low on the car as it gets anyway...
My thoughts....
