Old 05-13-2005, 11:55 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally Posted by SVXRide
Chike,
Congrats on the alignment. The tech did set each wheel to the stated camber settings, right? You're actually running more negative camber on the front than I am!
Given that you're still running 0 deg of toe - front and back - I really question the tech's statement that going to negative camber alone is going to take the understeer out.
Harry is right to keep a close eye on your front tires - my ES100s are getting a nice "rounded" inner edge with the -1.5 front and back - and I've got a couple of thousand miles on them with this alignment set up.
You might try upping the front tire pressure to around 50 psi just to see the effect on understeer (just make sure to bring the pressure down after you've felt what it does).
The car can be made to be much more neutral - it just take the right optional OEM pieces
-Bill
Thanks Bill. The tech gave me the alignment sheet at the end which had the stated settings at each wheel. There's absolutely no toe front & rear on my car right now.
I plan on monitoring the way my tires wear - good advice on playing with the tire pressures.
-Chike
2006 Steel Gray WRX TR (sold)
Old 05-14-2005, 06:00 AM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
Chike,
-Bill
"STOCK" SVX's rule!!
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 05-14-2005, 12:05 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Harry
You are so right, Obi-Wan Harry!!
-Bill (continuing to align himself with the autocrossing Force of life...)
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-16-2005, 04:51 PM
nordique14's Avatar
Who watches the watchmen?
I’ve been running -1.9* at the front and -1.5* rear on my other (non-SVX) car for about 5k miles. So far, the tire wear on the inside has been fine. And I run with 1/16” toe in. Amazing what a difference a good set of performance rubber and a good alignment make. Once I get the new suspension on the SVX, I’ll give ‘er a proper sporting alignment.
-Matt
Old 05-18-2005, 08:13 PM
Chiketkd's Avatar
My $122 alignment...
...came with a warranty, which allows me to go back and have them adjust the settings free of charge within a 6 month period. As I want my current summer tires to last a little while, I went back this morning to have my alignment settings adjusted. My current set-up is now:
Caster: factory
Toe: '0' front & rear
Camber: -0.5* on both front wheels, -0.2* on both rear wheels
-Chike
