Old 01-28-2002, 09:30 AM
Lowered SVX
oil leaking again......
after getting my camshaft and crankshaft seals replaced......i noticed the other day that i still have oil leaking. what the hell!!!???
another trip to the stupid mechanic.......arrgggghhhh........
"Too much fun to drive!"
Old 01-28-2002, 01:08 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
do you know what it is that is leaking? On mine, differnetial leaked till they replaced the diff. seal.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 01-28-2002, 01:19 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: oil leaking again......
One thing to do is to slip a piece of light cardboard under the car tonight, where the leak usually shows up (if you have to park outside, make sure to weight it down to avoid the wind blowing it away). Tomorrow morning, pull it out. Look at color, then, give the spot a "sniff." Motor oil, tranny fluid and gear grease have their distinctive "bouquets." That way you can, at least, narrow down what to look for. Tranny fluid could be your rack or a PS hose, or, a tranny cooler hose or tranny pan, etc. Motor oil could be an oil pan leak since you've had most of your seals replaced. Of course gear grease would lead you toward a diff seal leak. Just a suggestion.
Randy Johnson
Mike Davis -- at Reading VI
Old 02-01-2002, 02:29 PM
Lowered SVX
thanks randy.....
i am pretty sure it is motor oil. hopefully something simple. i will take it in this coming week and get it fixed. i need to get my left cv axle rebuilt and some new brake pads too. ahhh......the svx experience, always challenging.
