Old 05-02-2005, 09:06 PM
nysvx10 nysvx10 is offline
Need some part links/numbers
Does anybody have a link to subaruparts.com for inner tie rods and half shafts....I could'nt find it them on there..or even maybe a alternative cheaper source?
Thanks
Caleb
Old 05-03-2005, 03:08 PM
bump^^^^^^^
Old 05-03-2005, 05:58 PM
Inner tie-rods are parts 4 and 5 here:
Reference 1
As for half shafts (axles) look for remans eg. http://raxles.com/ as the Subaru ones are way too expensive. Some remans even have lifetime warranties.
Old 05-04-2005, 11:57 AM
ok I actually need the inner tie rod ENDS....any idea what number those would be...or a cheap source for them?
thanks
Old 05-04-2005, 06:06 PM
I don't understand your request. That's what I pointed out to you. The inners cost the same as the outers ($38.06)
Old 05-04-2005, 08:37 PM
Just going by what my mechanic told me..."you need new inner tie rod ends"..would those be #'s 2 and 3..Sorry if I'm confusing you.
Old 05-05-2005, 02:39 PM
I would think that 2 and 3 are the outer tie rod ends. It's almost always these ones that need replacing.
What are the symptoms?
Old 05-05-2005, 02:44 PM
The problem was discovered during inspection and now I need to have the "inner tie rod ends" replaced for it to pass. Mechanic says he found them for $140 each, so I dont understand why they are under $40 on subaruparts.com. Car shakes sometimes, steering wheel and car..(not during breaking). Then it will just stop....it's pretty random. So I'm not quite sure what to do here....
Old 05-05-2005, 04:25 PM
Mine did that for a bit too. My cause was a bad ball joint.
Old 05-05-2005, 06:26 PM
I don't know what causes the vibration, but right now I'm worried about passing my overdue inspection and making the garage happy by meeting their requirment of new inner tie rod ends..So back to this again,,,what ARE the inner tie rod ends?
Old 05-06-2005, 06:28 AM
red95svx
The inner tie rods (the tie rods closest to the rack) are #4 and #5. The outer tie rods, like the name implies, are further away from the rack, #2 and #3.
Old 05-06-2005, 12:19 PM
OK that helps alittle bit, but I'm still confused about the ENDs..are the ends attached to the ends or are the rods and the ends separate..if I ordered parts 4 and 5 would that make the mechanic happy by getting new "inner tie rod ends"?
Old 05-06-2005, 04:16 PM
red95svx
Yes. Technically they are called "inner tie rods" and not "inner tie rod ends." That is what makes your question confusing.
Old 05-06-2005, 10:41 PM
ok thank you..sorry if I was confusing..I was just going on what the mechanic told me.I will go ahead and order these for under $40, I dont have any idea why he quoted me $140 for each!
Old 05-07-2005, 06:49 AM
red95svx
No problem
Maybe his price included labor?
