Old 05-01-2005, 07:48 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
'95 throwing a code
21 Coolant Temperature Sensor or Circuit, thats the code im getting from my '95 and i dont know what it is or what it does. Any info is appreciated.
dustin
-Dustin
Old 05-01-2005, 11:22 AM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Clarify a sentence
Yeah, I had one of those go out.
Mine never did throw a code, but the symptom was the car would start fine and run fine until it was just before warming up. Then for about 2 minutes it would sputter and almost die, or it would die if I couldn't keep the rpm's up. And if it did die, it was difficult to get it started again. Once the car got completely warmed up, it ran fine again.
The service manual says the trouble symptoms are 1:Failure of the engine to start, 2:Erroneous idling, and 3:Poor driving performance.
That little monster is located on the driver's side, on the back of the engine. It's a 2 wire connector that (at least on mine) has a bronze color to it, and fastens directly onto the sensor instead of wires leading out from the sensor. Theres another 1 wire connector directly above it. They both are pointing toward your steering wheel, straight back.
You may have to remove your intake boot to see it. I am writing this by looking at my parts car, and the intake boot has already been removed. My head is about where the brake fluid reservoir is, and I'm looking under, and just to the inside of the intake manifold. It's directly across from the most inside cylinder, on the back of the engine. My wife has taken off with the camera for some Charity cancer thing this morning. I will snap a shot of it when she returns around noon or so.
The service manual says that the resistance between the 2 terminals should be around 30k at 68*F and should be around 400ohms at 176*F
I always get the prices of the sensors mixed up, some are $20, others are over a hundred. If I'm not mistakened, I think this is the $20 sensor. I would check subaruparts.com to be sure. It isn't difficult at all to replace.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 05-01-2005, 01:43 PM
OK.. Got the camera.
Pics of location are below.
Robert
Old 05-02-2005, 07:54 AM
red95svx
A common problem for Subaru's. We replace them all the time. Part # 22630AA041, retail is $26.95.
Old 05-03-2005, 12:35 PM
It's the cheaper of the 2 sensors so that's a good thing.
It's part #8 here:
Reference Link
