Old 01-19-2002, 09:49 AM
dart
Question torque specs
I'm replacing the drivers side front cv axle but don't have the torque specs when I go to button it up. Does anyone know the
ft-lb rating I need to torque the axle bolt, ball joint bolt, lug nuts ect. when I put it back together?
Old 01-19-2002, 10:17 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Axle nut = 123 - 152
Ball Joint to Knuckle = 33 - 43
Ball Joint to Ctl Arm = 79 - 101
Lug Nuts = 72-86
Specs are for lbs/foot. As always the first number is for used parts, the second for new parts. This allows for stretch of new fasteners. Many people think it's a range of tolerance. All front end parts that are pinned for safety are torqued to proper value and rotated further, if necessary, to align slot/hole for pin insertion. Never back off to align slot/hole.
Beav
Old 01-19-2002, 12:45 PM
dart
Lug Nuts = 72-86
Beav
Thanks for the info. You don't happen to wrench on the side do you?
Old 01-19-2002, 03:29 PM
Beav's Avatar
Not as old as Randy
Sorry, but I have almost no time for myself these days. I have been thinking about opening another shop but for right now I'm enjoying the simplicity of working for someone else. That and the doc said to start easing up a little bit...
Beav
Old 01-19-2002, 04:19 PM
dart
Beav
I wish I didn't know that feeling but thanks just the same.
Old 01-20-2002, 12:48 PM
Torque specs
That's a great bit of info to have on torque specs. I always thought the two numbers indicated a range. I use a torque wrench when mounting or changing my wheels. I always set the wrench halfway between the two numbers in listed the owner's manual. You're saying, on the used fasteners of my 92, I should be using the lower number or a little higher?
Old 01-20-2002, 01:20 PM
Beav's Avatar
Not as old as Randy
Actually anywhere in the 'range' is close enough, but the lower figure is what's recommended for used fasteners.
Beav
