Old 04-12-2005, 03:19 PM
dieingSVX dieingSVX is offline
on the jdm auto tranny, why would you need to replace the rear diff? thanks
Old 04-12-2005, 03:37 PM
drivemusicnow's Avatar
Poor College Racer
because the final drive ratio is different. the actual gears are the same, however its a final drive of 3.7 rather than 3.545. This makes it such that you require the rear diff, because the "front differential" is inside the tranny.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 04-12-2005, 03:41 PM
i see, thanks for the info.
Old 04-16-2005, 11:12 AM
danny, are you gonna rally your svx 6mt? Otherwise it has a 50/50 split that is traction enough. Trust me, Jesse's 6mt didn't skip a beat with a 165 shot of n02!!!!
Old 04-17-2005, 08:03 AM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
JDM tranny to drive??
I'm not quite sure why you guys rave about the JDM tranny as regards to drivability - my family has two JDM's and they both understeer like ba$tards without even pushin' em too hard. In fact I just about pulled myself off the road the other day as mine couldn't claw it's way through the corner. Certainly doesn't feel like a rear biased AWD!
My tranny is in pretty good nick too as far as I'm aware, and camber etc is all per standards.
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 04-19-2005, 12:28 AM
I am more racing cars on the highway (there still no real police presence to watch roads...).
The major cars i beated so far are the 2001 - 2002 BMW 330ci and the 97 impreza turbo (at the 100mph run).
and i am still running on my auto tranny, my six speed is still in my garage, just waiting to resolve the turbo matter in this forum...
Old 04-19-2005, 12:35 AM
I don't have this problem, understeering and stuff... you should check your wheels balance. if your front wheels are regulated to their maximum outer distance, you will have this problem. you should squeeze them to the inside as much as you can. and if you have aftermarket wheels, just tell the guy to replace your front ones to make them smaller hence have a better grip than the rear ones. For example if you are running on 8" aftermarket wheels, just replace the front by 7.5" or even less, you will have a better grip. and you can even go to the extreme, by installing new tyres in the front wheels and used (midlife) on the back wheels...
Old 04-25-2005, 03:37 PM
Poor College Racer
First you really don't want to get different sized wheels because what you're talkinga bout with different sized outer diameters of tires is what F's with the transfer clutchpack.
I'd suggest playing around in a parking lot. I've found in my US version, that with hard throttle application, my car slides completely neutrally. (i do have extra stereo weight in the back) but with light throttle, and taking a moderate turn, the front end can just slide one me. I think mbtolozcko's rear sway bar would be a good solution to neutral handling all the time
Greg
Old 04-25-2005, 07:07 PM
Jnthn_Sctt Jnthn_Sctt is offline
Maybe a touch OT
How much of a handling difference would swapping a Euro spec tranny for a US spec tranny really make?
I'm going to have to replace / repair my tranny in the next year or so max, and was considering going with a Euro spec auto and have it worked over by Level10 in Jersey.
A six speed would be nice, but I've gotten used to the auto (I'm gettin' old too.) And would like peoples opinions on what the difference would be? Any Euro or Aussie drivers input would be tremendously appreciated.
Jonathan
Good people sleep peacefully in their beds at night, only because rough men stand ready to do violence on their behalf.
Old 04-26-2005, 03:12 AM
A flight-less flyer
Yes, you don't want to screw with different sizes Silverspear - the rear bar in my case is a much better option. In any case, putting smaller tires on the front would make it understeer even worse I would have thought.
Just Crusin'
