Old 09-22-2004, 04:32 PM
Szalkerous Szalkerous is offline
Send a message via AIM to Szalkerous
HORRIBLE Motor Ticking after long sit.
When I start my SVX I hear a constant loud TICK TICK TICK coming from under the intake. It is not the plugs, and not coming from a side of the motor. Car sat from Feb till about three weeks ago. I start it weekly now, but it developed a gasket leak on the driver's side. Has brand new oil and filter. Checked oil and it does not leak while it sits. Help please! The clicking sounds awful and does not go away after the car warms up!
-Sz
1994 SVX LSi - Black / Beige - 139k miles SOLD!
1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride.
2004 Chevy Silverado Z71 - Blue LT2 luxury package
Old 09-22-2004, 04:49 PM
svx_commuter's Avatar
See if it's louder when you listen at the side under the car behind the front wheel. It could be the flex-plate.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 09-22-2004, 11:12 PM
THAWA
im sure 6 months of no use would make for bad hydrolic lash adjusters, mine sounded like crap when they sat for 19 days. It went away after a couple days when the air finally got out. You can bleed em if you want, or just wait for it to semi correct itself. Least that's my guess.
Old 09-23-2004, 02:14 AM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
Hydraulic lash adjusters..
How do you bleed 'em??
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 09-23-2004, 05:27 AM
Only leaks oil when running and ticking (Lifters) could be a bad seal on the oil pump....this would cause a leak when it was running, and allow air to get into the oil while being pressurized causing it to froth up, and make your lifters tick....
My thoughts on it....but diagnosing over the internet is hard to do...
Old 09-23-2004, 10:20 AM
Hmmmm
Would it be easier if anyone with some garage know-how and a broadband connection if I take a short video of it?
The ticking comes from the top center of the motor, immediately under the intake. It does not come from either side. I may try to obtain a steth and determine a pinpoint.
Question about leak- Is the oil pump located to one side of the motor? I noticed that the smoking comes from under the driver's side of the motor, in the center.
And FYI- Oil Pump was replaced 2 years ago by Subaru of Nashua, NH.
Old 09-23-2004, 11:20 AM
Originally posted by Szalkerous
Hmmmm
Sounds like a valve cover gasket to me, from that location.
The Oil pump is really in the center of the motor, but the timing belt could spread an oil leak to one side or another...and let it leak out of the T-Belt covers...
Old 09-23-2004, 11:29 AM
dcarrb dcarrb is offline
The oil pump's up front and center. Smoking could be engine oil dripping onto the exhaust from a leaky cam cover gasket, or ATF from the lines that run to and from the radiator/cooler.
With the entire valvetrain located at the east/west extremes, a loud tick from beneath the intake can't be a good thing. I've never had the flexplate problem many have described here, but I think if I were you, I'd explore that possibility a bit further.
dcb
Old 09-23-2004, 09:38 PM
THAWA
yeah i'd bet valve cover gaskets aswell.
Old 09-23-2004, 10:08 PM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
How do you bleed your lash adjusters? My engine has ticked sence i got it :-/
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 09-24-2004, 01:03 AM
THAWA
take off the valve covers, pull out the HLA's, dunk em in oil, and squeeze the air out of them. I'm sure there's a more indepth method to that though .
Old 09-24-2004, 05:33 AM
The following would have to come off....
Valve covers,
Timing belt,
Cams and cam holders
Old 09-24-2004, 02:16 PM
nsm484's Avatar
Teh Geek
Any Method, that someone has actualy done, and was sucessfull, at reducing/removing the tick noice, without tearing into the engine?
Old 09-24-2004, 02:58 PM
I've heard of someone putting ATF in their engine, going for a brief agressive drive then changing the oil again.
The ATF is supposed to clean out the system.
Old 09-24-2004, 08:17 PM
THAWA
Valve covers,
Timing belt,
why the timing belt and cams?
