Old 06-15-2004, 02:20 PM
Naim's Avatar
Naim Naim is offline
Send a message via Yahoo to Naim
Help, I am wondering if this rim and tire size will work...
Ok, I am thinking about getting these rims 17x7 - PCD 5x114.3 - ET 42. ET 42 means that the offset is 42mm.
The tires are 225/45R17...
Will this offset (42mm) push the rim in or out?
Is this a bad offset to go with??? I want to make sure that the rims and tires do not rub against anything.
Also I do not want to stress out the wheel bearing with an off set that is too extreme.
I now it's a slight narrower rims and am wondering if this compensates for the difference in offset.
Thanks...
I bought the car for my wife, but it's my new toy :-)
Old 06-15-2004, 02:32 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
This size will probably work. It will be approx .27 inches closer to the outside of the wheel well.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 06-15-2004, 02:40 PM
Word to Yo Motha
Nevermind. Since you are using the same widthy of tire (225), There will be about a half inch difference.
Collin
1995 L AWD
Locker
Old 06-15-2004, 05:38 PM
Naim's Avatar
Yeah, but with the rim being 7 inches wide, and not 7.5 (as the factory wheel is), wouldn't that put the outside location back in the same place???
Old 06-15-2004, 06:30 PM
mbtoloczko's Avatar
sans SVX
The rim and tire should just barely fit without rubbing (on the outside). A more appropriate tire size for a 7" wide rim is a 215/45-17.
Mychailo
Visit my locker
Old 06-16-2004, 12:07 PM
Naim's Avatar
I was told that the 97 SVX acme with a 7 inch wide rim... Does anyone know what the backspacing was on that?
Old 06-16-2004, 12:13 PM
Word to Yo Motha
I thought they just changed the tire size...
I agree with Mychailo. You should use a 215/45-17 tire. To answer your previous question, even though the wheel is narrower, the tire would still be the same size. Thus leaving you with very small clearance. With a 215 tire you would be 8mm closer to the edge of the wheel well. A 225 tire would be 13mm closer.
Tire width/2 - offset. Take the difference of the two calculations to find change in distance.
215 also fits better on a 7 inch wheel.
Collin
1995 L AWD
Locker
