Old 06-08-2004, 03:26 PM
red95svx
Re: Talking about parts...
Originally posted by Chiketkd
Hey Dave,
If my transfer clutch is broken is this the part that I'll need to replace it: Part # 33123AA150
Thanks!
-Chike
P.S. That part runs $251.24 at Subaruparts.com. What price can you give me? I may need to order this part later in the summer...
When we do a Legacy transfer case overhaul we replace the transfer case with a new one, put in new drive plates, new driven plates, new roller bearing, and usually a new transfer clutch solenoid valve. I don't recall ever having to replace a drive shaft though. Again, this is on the Legacy, YMMV depending on what is actually wrong with your car. You very well could need a rear drive shaft.
Old 06-08-2004, 03:31 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: Re: Talking about parts...
Merci! I would've PM'd you, but your box was full...
-Chike
Originally posted by red95svx
I'll check tomorrow at work for you.
2006 Steel Gray WRX TR (sold)
Old 06-08-2004, 03:43 PM
red95svx
HehE. I just edited my post!
Old 06-08-2004, 03:44 PM
red95svx
Your cost for that rear drive shaft would be approx. $220.
Old 06-08-2004, 08:21 PM
Chiketkd's Avatar
Thanks Dave. From the sound and feel of things, the 'teeth' on my rear drive shaft seem to have been damaged/shredded by the previous owner. UberRoo did a welding fix when his car had the same problem, but I just wanted to swap in a new part in its place...
I think the rear drive shaft is all I'll need for the fix, if it doesn't work, I'll get some of that other stuff you recommended. I'll PM you in the coming months to order the part as well as those oil filters! Need to make some money first...
Thanks!
-Chike
Old 06-08-2004, 09:02 PM
Chiketkd's Avatar
Actually, put a hold on that rear shaft...
I plan on doing a 5spd swap in the next year, so I really don't want to invest in new parts since I'm not looking at the 'longterm' with this tranny. If I can't find a transfer clutch assembly in good condition from an SVX parts car, I'll PM you and order the parts...
-Chike
Old 06-09-2004, 09:20 AM
red95svx
Originally posted by Mr. Pockets
Hmm...I wonder. The car is able to 'limp home' even with certain failures, so I wonder what would happen if either (or both) of the crank angle sensors failed. But I think Thumper's car is an example - it's getting an out-of-range reading from the sensor.
I wonder, now, why there are two sensors...they both read off the same wheel...
OK. Found some info at work. Each crank shaft sensor actually reads from a different gear on the end of the crankshaft. Sensor #1 reads a gear that has 12 evenly spaced teeth. This tells the ECU where the crankshaft is every 30 degrees. Sensor #2 reads a gear that has 6 unevenly spaced teeth. There is a group of three teeth, then a group of two, and then one by itself. According to the book sensor #2 and the camshaft sensor are used for injector firing. Sensor #1 tracks the overall progress of the crankshaft through its 360 degree rotation.
