Old 03-04-2004, 07:17 PM
lee lee is offline
Call for topics
I have been reading a thread on fuel pressure that I find interesting. I'd like to suggest a set of topics for discussion in the technical forum and see if anybody a) seconds, b) rejects, or c) adds on.
There are so many people with such a store of knowledge here....I love this place.
Anyway here's a short list off the top of my head:
Suspension:
Affect of cast & camber on handling
Affect of increasing/decreasing sway bar size, front/rear
Transmission:
What the various stall speeds in a torque converter mean and why should I care
Level Ten claims for increasing ATF flow thru the valve body...if it's so good, why didn't the factory do it, i.e., what are the down sides
Engine:
Effect of removal of harmonic balancer - primary & secondary balance (and any others) in a flat-six
Old 03-04-2004, 08:34 PM
Bobb Bobb is offline
Trany
Hi Lee, LarryIII posted recently that starting with model year 1994 SVXs, the fluid flow was increased in the transmission to improve cooling.Take care, BOBB
Old 03-05-2004, 04:50 AM
LarryIII LarryIII is offline
Lee & BOBB,
I think that it was the '96 model year that they drilled out the oricifice hole in the hydrovalve by 1/16". In '94 they replaced the radiator so they did not have the wire mesh in the ATF cooling tube in the cooler.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 03-05-2004, 06:22 PM
Thats a good idea Lee, I don't mind writing on anything automotive, just a lot of the time it's better for me to answer questions, as I might get a bit long winded, on my own.
Having taught Automotive, I know the range of auto knowledge that this board's readers have and try to write accordingly. But the missing link is the feedback that you rely on to access understanding. I don't know if it is understood or not, if people asked questions about the bit they don't understand, I could explane that better, or expand on any point, if some one needs to know more. Hard to decide, don't want to bore anyone.
Having said that, I don't have practical experience in working on this car, due to the one arm sitution, so I rely on the experences of the WORKERS to provide the practical side.
I'll go along with anything you work out.
p.s Know nothing about air conditioning.
Old 03-05-2004, 06:32 PM
Smile Oddball answer
Hey Harvey
Air conditioning is totally like, cool, man.
Old 03-05-2004, 06:39 PM
lee lee is offline
...snip.
Not to worry, I like long winded. Coming at a topic from various points of view helps me understand. Maybe I'm dense, but if I hear an explanation one time, from one viewpoint, it just doesn't sink in too well. But if a couple of my friends argue out a point until they agree (either technically, or that it's time for a beer break), I find it lodges pretty good in my old brain cells. I think its because inside I'm arguing along with one then the other until I "see" better.
OK, so I'll ask the first one. Can you explain how sway bars affect under-over steer. I'm probably wrong, but for some reason I think a softer rear bar (or stronger front bar) helps reduce understeer. I understand mechanically how a sway bar puts force against a wheel when flexed under cornering loads. I also know what understeer and oversteer are in terms of plowing or rear-end hanging out. But I'm missing some serious connection information because I can't translate changes in one to effect on the other.
Old 03-06-2004, 05:44 AM
wawazat??'s Avatar
Yeah, I'm still around
You might like this site lee. It has a section on sway bars, or more correctly anti-sway bars/anti-roll bars.
http://www.grassrootsmotorsports.com/swaybars.html
Todd
Down to none
