Old 03-04-2004, 04:53 PM
Component Driveshaft
Just was wondering how you tell the component driveshaft from the single pice driveshaft. thanks in advance for any and all help
Old 03-04-2004, 05:53 PM
mbtoloczko's Avatar
sans SVX
The two different driveshafts that were used for the SVX are both 2-piece units. The earlier version uses a CV joint at the center, and the later ones use a u-joint at the middle. If by "component" you mean separatable halves, then that would be the later version with the u-joint at the center.
For driveshafts, another option to keep in mind is one that Huck discovered. It appears that the driveshaft from a '97 Legacy Outback 5MT the correct length for a 5MT in an SVX. All that needs to be done to fit it to the SVX is cut off the old middle mount and use the mount from the SVX driveshaft.
Mychailo
Visit my locker
Old 03-04-2004, 10:07 PM
alex_umn alex_umn is offline
I live in a drawer!
Send a message via AIM to alex_umn
Here's a pic comparing the two as well...
http://www.subaru-svx.net/photos/fil...x_umn/1426.JPG
Front to back, sorta: Claret 1992 Subaru SVX LS-L, JDM STi open front diff six speed, STi tranny mount, Kartboy shift bushings, WRX CD changer, rear R180, battery in trunk, Stebro exhaust.
2000 Specialized RockHopper A1 FS, converted to singlespeed 36:15.
I like my cars with too many gears and my bikes with too few...
Old 03-10-2004, 12:10 PM
Can anyone verify that the 97 outback 5mt will work without modification other than switching the center support out? Any info is greatly appreciated.
Old 03-10-2004, 12:34 PM
mbtoloczko's Avatar
sans SVX
I'll have the answer in a week or less.
Mychailo
Visit my locker
Old 03-11-2004, 11:47 AM
Does anyone know what year/model of the svx came with the seperating driveshaft???Any leads to find one anywhere? Just thougth i'd ask. Thnaks in advance.
Old 03-11-2004, 12:00 PM
I live in a drawer!
I feel like I keep posting about this web site but it has worked well for me in the past: http://www.car-part.com
Choose 1992, Subaru SVX, Rear Drive Shaft. In the listing of parts available you can see ones that have separate pieces; not sure when they went from one to two piece, though...
Hope this helps...
Old 03-11-2004, 12:10 PM
mbtoloczko's Avatar
sans SVX
'94-'97
Mychailo
Visit my locker
Old 03-11-2004, 02:38 PM
GreenMarine's Avatar
From POST-***** to LURKER
I am interested in this too as I have had driveshaft issues ever since my install...
Old 03-14-2004, 07:43 PM
strange179 strange179 is offline
Still a member
Send a message via ICQ to strange179 Send a message via AIM to strange179 Send a message via Yahoo to strange179
a cuople pennies
I saw this and had to throw in a couple bits of info that might help here. First one is that the drive shafts that had u-joints in them were from the "L" or "LS" SVXs. The "LSL" and later, the "LSi" SVXs had the supposedly smoother, quieter CV type center joint in the shaft.
The second one is that even the CV type joint is seperable, it just takes more work to get it apart. I posted a rundown of what the drive shaft shop told me they did to mine in my 5-speed install thread.
Hope this helps and I too am interested in the outback driveshaft info.
Jay
Speed Safely
Subaru, All We'll Drive
Black '92 LSl 270Kmi 5MT (W00t! for 1/4 million on 4/27/07)
Laguna Blue '94 L about 130Kmi (I think) for parts, in storage
previous: Green '92 LSl 253Kmi 5MT (sold to ron post moose adventure, sold to someone else)
previous: Maroon '92 LSl 130Kmi +- (sold to Ron, mashed by moose, crushed)
Black '89 XT6 5spd AWD (storage)
Old 04-01-2004, 02:29 PM
Just curious if you heard anything yet?
Old 04-01-2004, 02:38 PM
Re: a cuople pennies
Jay
I checked out your thread a few times but am unsure if they were actually able to seperate the cv and if they did did they just replace it with a new cap or did they use the old one? Also do you know if they had to cut it off? Because thats what the shop i took it too said they would have to do. Just curious thanks for the help so far. Its as always greatly appreciated.
Old 04-01-2004, 04:24 PM
wawazat??'s Avatar
Yeah, I'm still around
I trial fitted it and thought it was too long. The DOJ was compressed to far for me to feel comfortable with using it in the long term. The carrier bearing mount also places the joint at too much of an angle for any hope of longevity.
I ultimately had a hybrid shaft made using the SVX carrier bearing and a mix of parts of the Legacy and SVX shafts to achieve the correct length, correct offset, correct carrier bearing, and not use the offset mount/adapter used in the Small Car kit. Cost for the above work was $160.
Todd
Down to none
Old 04-01-2004, 04:44 PM
mbtoloczko's Avatar
sans SVX
Sorry, things have been taking a bit longer than anticipated. 5MT goes in the car tommorrow, so I'll have a detailed answer on the fit this weekend.
Todd, I hope the driveshaft I got (from a '97 Legacy Outback 5MT) is different than the one you tried.
Mychailo
Visit my locker
Old 04-03-2004, 05:54 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
My 94 LSi has a universal joint. Seperates nicely. Makes pulling the tranny so much easier.
UberLocker
