Old 11-03-2004, 12:07 PM
RobSVX
I'm doing this tonite... should be fun ! Mmmph
Old 11-03-2004, 03:13 PM
Thanks one and all.
I have to have my RHS cover done soon, so I will just copy all the info into a step by step description, and give it to the man, to do it.
Thanks Arthur and Matt.
Old 11-03-2004, 05:29 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Some times ya wonder why ya bother...
I posted this not too long ago:
http://www.subaru-svx.net/forum/show...ht=valve+cover
Includes gaskets & washers
Old 11-04-2004, 07:16 AM
RobSVX
Driver's Side done. It wasn't bad at all, but then again, I've been pulling motors since back in HS for fun.
I will admit, that you folks helped. Getting it out, once the bolts are removed, was all you baby !
...Also replaced the P/S Pump O-ring. I was wondering where that fluid was coming from...
Will get the Pass side Cover done next.
Just have to figure out the 'indigo' dash install next ?
Old 06-06-2005, 05:21 AM
pylon500's Avatar
pylon500 pylon500 is offline
the Flying Member
Send a message via AIM to pylon500 Send a message via Yahoo to pylon500 Send a message via Skype™ to pylon500
Docking Rings
Hi Guys, just cleaning up an old post in case any-one else looks it up, or you could say a very late update
Hey,DO NOT USE DOCKING RINGS!!!
These things seemed to work great for (how long has it been?) about seven months, then I just had oil coming from EVERYWHERE!!, and when it runs down over the exhaust system, you can get some real funny looks!!
Basically these things are some form of soft rubber, and with time, heat and oil attacks them and they turn into something worse than fresh bubble gum on carpet.
Eventually, internal pressure (yes, my dipstick pops up) blows the goo out of the screw hole, and you disappear in a cloud of smoke!!
Lesson learned; use SUBARU rocker cover gaskets, BUT, order the common ones used EJ22 engines, they're cheaper.
Arthur.
'80 DL 4x4 Wagon-White (gone)
'91 DL 4x4 Wagon-White (gone)
'92 SVX LSi Burgundy/Black with wing. (gone)
'04 Liberty B Spec 3.0R wagon-Silver
'02 Outback 2.5 wagon-White For Sale
I Don't Drive Fast, I Just Fly Low!!
I've moved to Taree , check out my progress at Picasaweb.
That's a 'V' in SVX dammit!
