Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 03-01-2004, 08:16 AM
Chris_CH
Pipercross are filter
Hi,
I'd like to know if some one already tried to install a PiperCross Vector air system on a SVX, if yes what the fuel consumtion become .......
The pipercross system is below :
http://www.performanceairfilters.com/main.html
Thanks
Old 03-01-2004, 05:14 PM
immortal_suby's Avatar
Thread Killah
First time I have seen or heard of it. It looks like an interesting concept. The flexible hose would make it pretty easy to locate the filter where you need it.
Locker Link
2015 BRZ Limited 6MT
Old 03-01-2004, 06:09 PM
Mr. Pockets's Avatar
Moderator
Before I move this thread to the mod forum, I'd like to say that the copy on that site is total garbage.
"The unique design of the filter cone and the inlet 'tune' the moving air flow to increase its speed and therefore its pressure maximising the laminar air flow into the engine, again resulting in increased power."
I don't even know where to start... They must know this product is bogus - they actually call their filter 'reverse flow technology,' which makes sense since they get Bernoulli's principle backwards in their ad copy.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 03-01-2004, 08:14 PM
add a Tornado device to that, and .... Whoa! you might need a parachute on the back!
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 03-01-2004, 08:31 PM
Moderator
Originally posted by Landshark
add a Tornado device to that...
Oh, don't even get me started on those...
2005 Outback
END OF LINE
Old 03-01-2004, 10:02 PM
Invisible avatar
Wink
The flexible hose would make it pretty easy to locate the filter where you need it. [/B][/QUOTE]
Yes, & I especially like the hose with the garter system attached.
Ron (who cares if it works, I like the feel of it).
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 03-02-2004, 07:50 AM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
In my opinion, albiet an inexperienced one, it seems that despite all their technobabble trying to "fluff" the product...the ability to get more direct airflow from the flexible hose, like putting it somewhere near the airdam, seems like a valuble enough property of the item. Right?
-Andrew
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 03-02-2004, 07:55 AM
Moderator
-Andrew
You're probably right about that, but their tubing dosn't look like anything special. And since their 'reverse flow filter technology' is crap, you might as well skip the whole thing andd use dryer tubing if you want to 'relocate' your air intake for some weird reason.
2005 Outback
END OF LINE
Old 03-02-2004, 06:51 PM
The Molinator
DAAAAAAAAAAAAAAAAAAAAH!
Wanna buy a Tooooooooornaaaaaaaaaaaadooooooooooo! (cheap)
I had to take it out. . . . . . . . I almost snapped my neck from the added "reverse flow technology thrust"!
Jim
Old 03-02-2004, 10:03 PM
mikecg's Avatar
mikecg mikecg is offline
I likes the models!!!
I straightened out my factory intake using a hacksaw and some creative enginering (read as Duct tape), and installed a K&N Drop in filter. I imagine it workes just as good. When I straigtened the stock on out I angled it toward the radiater a little. I noticed a gap between the bumper and the radiater that allows fresh air to get into the fender well.
Old 03-03-2004, 08:50 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Pipercross
I remember Rallispec used to sell intakes with the Pipercross air filter to the 2.5RS crown. I have a Pipercross panel air filter in my Outback Sport that I've had for ages. It was just sitting in my basement until earlier this year when I uninstalled a previous mod. Doesn't seem like anything special (the panel air filter) but it doesn't seem to hurt.
I like the idea of the air filter being closed off from the engine bay. Since it's closed off, it better be a BIG air filter since the SVX can swallow some air.....stock. Otherwise, it'd be a waste of $$$.
Anyone???------->
Kevin Thomas
***R.I.P***
Old 03-03-2004, 11:16 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
I think Subaru can be trusted to design an effective intake. Ever notice how it kinda resembles the intakes on, oh I don't know, say, every single modern car built today? I think if there were extra performance hidden in a better intake, the Subaru engineers would have found it. ...but what do they know?
UberLocker
Old 03-04-2004, 07:39 AM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Good point!
Actually I agree with you. The only way people are going to know is to test different intakes out. Engineers are always making compromises when it comes to cars. I wouldn't be surprised if the compromise in the SVX is some luxury (noise comfort) vs performance when it comes to the intake.
I hate arguing this though. If I had an SVX, I'd simply try an intake, put it on a dyno or 1/4 mile track and report the results. I thought the same thing with my XT6 as far as the intake is concerned. Ended up increasing hp/torque throughout the powerband and in some places by up to 6hp. No, it's not mind altering hp but a difference nonetheless.
It would be nice to test these things out to find out though. I wouldn't mind trying out that air filter if it was readily available. I don't think there are any vendors in the U.S. that sells them looking at the site.
Kevin Thomas
***R.I.P***
Old 03-05-2004, 08:34 PM
UberRoo's Avatar
SVX Appeal
It is true that there may be a compromise made, and noise reduction is a good example because it's a major concern of the manufacturer. Nearly all of the principals that work for exhaust systems also apply to intake systems. Strange, but >100% volumetric efficiency is possible (and common.) The scavenging effects that make this possible also have an effect on noise - they often tend to reduce it. I suspect - no - I'm pretty certain that Subaru has made use of this in the intake as well.
There's one way to test the intake restriction and be sure. Do a vacuum test just upstream of the throttle valves (or downstream of whatever part might be causing a restriction.) You'll probably need a REALLY high-resolution vacuum gauge because the restriction will be so incredibly low. Stick the end of the vacuum hose wherever a restriction might exist.
A primitive gauge can be made with a clear hose hung in a "U" shape and half-filled with coloured water. One end is vacuum, the other is atmosphere, the differential in fluid level is your indicator.
UberLocker
Old 03-06-2004, 11:47 AM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Intake Restrictions
Here's an article that talks about exactly what you are describing.....finding the restrictions in an intake. Eliminating Negative Boost
Really nice article to read.
A Dwyer Magnehelic Differential Pressure Gauge is a good gauge for measuring how much of a restriction is in your intake before and after certain points.
Kevin Thomas
***R.I.P***
