Old 02-15-2004, 08:33 PM
njboys808
Unhappy Thumping sound from rear when turning
Hi Guys,
I just replaced a roller bearing in the tranny. I reinstalled the the tranny and everything seemed fine till I made a tight turn and all of sudden a began to hear a series of thumping sounds coming from what appears to be the rear axel. As soon as I straighten out is goes away. I had heard this sound before but only once or twice. Anyone know whats going on and how I can fix it?
Thanks
Old 02-16-2004, 07:53 AM
gcookaustin
Your AWD might be "binding." Do a search for that term.
Old 02-16-2004, 08:45 AM
zavikan zavikan is offline
hmm
If its your AWD, put in the fuse that puts the car into FWD mod(check manual for which) and see if it still does it. If it goes away, you have your answer. if not.. keep looking!
Old 02-16-2004, 03:27 PM
Re: Thumping sound from rear when turning
Originally posted by njboys808
Hi Guys,
Thanks
Why did you replace the race? What was it doing that caused you to go in there??
Old 02-16-2004, 03:30 PM
njboys808
I replaced the bearing because it broke and I found the pieces in the front differential oil.
