Old 02-13-2004, 12:31 PM
96svxer
Oxygen Sensor Threads?
what is the thread pitch for the oxygen sensor? I found a 3 wire universal with these measurment, will it work?
Metric 18x 1.5 Thread.
Are all three wire heated oxygen sensors interchangable as long as I cut the leads, and sotter?
link
Old 02-15-2004, 10:46 AM
svx_commuter's Avatar
I used the universal O2 recently on my 97 Impreza. The leads had to be cut and then put into a splice box that keeps them water tight. It was very time consumming to make the splices, at least a half hour per sensor and I do not plan on going this route again. The splice box is also quite large(1.5 x1.4x3.0) and will not fit in thru small holes. While this should not be a problem on the SVX but it is something to consider.
Besides the thread size, the electrical characteristic also have to be matched. If the seller can't match it to your SVX you may not want it.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 02-16-2004, 06:00 AM
96svxer
Thanks
