Old 02-02-2004, 12:56 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
water in headlights
Since I was in a head-on collision I have a problem with water in my front lights, on one side it's so bad that the beam is barely visible, the other has mild condensation. My mech says the seal is busted and recommends replacing the front lights at a cost of $900 (about 350 for each light, plus labor). Granted, it's not my money (I didn't cause the accident) but 900 seems a little steep. Is it possible to reseal these things? Would the clear headlight kit from small car be a replacement option?
Old 02-02-2004, 02:56 PM
Mr. Pockets's Avatar
Moderator
So $700 in parts and $200 in labor??? That's kind of...a lot, if you ask me.
Anyway, if you're careful about it, you can reseal the headlights. There may be a how-to for taking them apart in the (go figure) how-to locker.
As for the small car kit, the kit itself wouldn't solve your problem, but the same process for taking them apart would be involved - so you may solve your leaking problem at the same time.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 02-02-2004, 03:30 PM
Alycone's Avatar
Thanks, I was wondering if cleaning and resealing would work.
After driving in the rain one of my lights has enough water to keep a goldfish happy, the other just has a lot of condensation. and I can watch the water drip into the side light (next to the goldfish-ready light), but the water doesn't build up or fog much.
Old 02-02-2004, 04:35 PM
Moderator
Are you sure that the plastic lenses on the headlights aren't just cracked, letting water in? You did have an accident, you said - anyimpact hard enough to damage the seal could have broken those lenses just as easily.
2005 Outback
END OF LINE
Old 02-02-2004, 04:57 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Check my page on how to clean headlight. It'll tell you how to open them up to seal them
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 02-03-2004, 08:28 PM
sleepem's Avatar
sleepem sleepem is offline
A Little bit less Junior
I'd think about the headlite clear lens replacement. It's a lot cheaper, the light is better if you have even a little haze to your lenses and the clear covers are attached with silicone sealant so should keep out the water. See pix of mine in my locker.
If your casing for the headlights is cracked, then this may not help. try to see where the water is entering. Don't leave them wet for long, the reflectors are front-silvered and will start to turn dark from the moisture and dirt
1992 Dark Green LS-L @ 300,000
I'm only 2nd owner, Burns no oil!!
Also in Family: '04 Nissan Murano, '98 Lex GS 400, '81 Accord, & '88 Civic w/ an Acura ZC engine.
Old 02-04-2004, 08:04 PM
if you're not paying for it then why not get the new headlights and sell the old ones?? New ones look like glass!
