Old 12-24-2002, 05:25 AM
fasteract fasteract is offline
245/45-16 tire a "no-no"?
Search of the Archives suggests the answer but curious if anyone has had this size tire, 245/45-16, on their SVX without a rub problem ?
Merry Christmas/Happy Holidays to ya'll,
Craig
Old 12-27-2002, 06:08 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
The archive is DEAD wrong.
I'm running Dunlop SP5000s in 245-45-16 on stock 16x8 rims (I know the specs say 16x7.5 they are wrong, we measured them at 8" wide @ the tire shop)
So far put about 1500 miles on them. No rubbing, even under full load/full compression. You might even be able to fit some 255s if you rolled the rear fenders a hair.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 12-27-2002, 02:55 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
I just went out and measured my spare stock rim,and it is definetly 16x7.5. The guy at the tire shop must not know the correct place to measure a rims width.Here is s ite with the info.
http://www.rsracing.com/tech-wheel.html
Old 12-28-2002, 09:29 PM
Strictly Subaru
Hi guys, no need to get upset here...... I've mentioned this before, and I can send pic's - You can run 245's on the 7.5 inch rim. That's the legal max for a 7.5 inch rim. I'm running 245/45 x 17's without a problem on a 7.5 inch rim, and I agree with the above post stateing that you can run 255's with a slight "massage-ing" of the rear inner fenders.... There is lot's of room on the front for 255's. I mounted a set on the front with no problems, however the back was just a hair to close for me. I wasn't keen on trying to massage the rear fenders.. So I went back to the 245's all the way around. Just my 7 cents worth....
Old 12-28-2002, 09:38 PM
Earthworm's Avatar
Meow!
Has anyone rolled their rear fenders to fit larger tires? I'm curious to know how (bad) it would look.
Old 12-29-2002, 02:46 AM
Cool page.
Sux for WRX owners cause they must have 6" wide rims then
The place that measure/mounted mine used a caliper on the ourside of the rim (below the lip) which measured 8" then they stuck it on a WRX wheel which was 6.5" so that would mean theirs are actually 6" v. 7.5" on the SVX.
Either way the 245-45-16s fit fine with no buldging on them and clear the fenders w/o issue.
-mike
Old 12-29-2002, 08:21 AM
CigarJohnny's Avatar
CigarJohnny CigarJohnny is offline
Send a message via Skype™ to CigarJohnny
Wink tsk, tsk...
-mike
Wheel width must be measured on the inside of the wheel where the tire bead actually sits, not from the outside. Shame on your tire guy for not knowing better!
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX)
Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting.
Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well.
You can tell the lack of craftsmanship by the wrinkles in the duct tape.
