Old 12-13-2002, 12:42 AM
DavieGravy DavieGravy is offline
Creaking noise behind steering wheel
It happens when I turn my wheel, but not for the entire rotation.
I had a similar problem on an older car of mine, but it gave me a grating sound. The design on this car consisted of metal flaps (attached to the wheel) that rub along a metal circular contact. (underneeath where the wheel bolts onto)
This supplied a conection for the power steering buttons on the wheel. I relubricated them and the sound went away.
Although I don't know about the SVX. Is it easy to take the steering wheel off and what might be causing the problem? Specifically, it sounds like a door squeeking.
Thanks in advance.
Old 12-13-2002, 04:40 AM
LarryIII LarryIII is offline
Do NOT take the steering wheel off. You may deploy the airbag.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 12-13-2002, 07:12 AM
Green1995SVX
Larry, I have removed my steering wheel a number of times with no issue. Just make sure you disconnect your battery and I usually pull the Airbag fuse for good measure.
Mike
Old 12-13-2002, 07:31 AM
want-a-fast-svx want-a-fast-svx is offline
Send a message via AIM to want-a-fast-svx
im curious
as to what this is as well...Its only happening on mine when you turn the wheel either way at around the 1/2 way mark...any help is greatly appreciated
Old 12-13-2002, 12:47 PM
When i said power steering buttons on the wheel, I meant cruise control buttons.
It only happens about half way on mine too.
Old 12-13-2002, 01:55 PM
Green1995SVX
Maybe the clockspring causing the noise?? I have a spare if you need one
Mike
Old 12-13-2002, 02:06 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
The creaking noise behind MY steering wheel comes from me.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 12-13-2002, 03:49 PM
Thanks Mike. I think I'll try and take the wheel off this weekend to see what it is, making sure I disconnect the battery and the fuse. Is the wheel easy to take off?
Old 12-14-2002, 12:00 PM
Green1995SVX
Yes, it is.
There are two plastic panels, one on each side of the steering wheel. They snap off. Snap those off, and they will uncover 2 T30 Safety Screws. Remove those. This will loosen the airbag. You can now remove the airbag. Unplug the airbag and set it aside. There will be a large nut (17mm?) holding the steering wheel on. Loosen the nut almost all the way, leaving it still threaded onto the stud by a few threads. Then pull out on the steering wheel as hard as you can. It will take a lot of force, but then the steering wheel will break free. Having the nut threaded on will prevent the steering wheel from flying up in your face. Take special care not to change the position of the clock spring, or if you do, make a note of where it was when you took the wheel off.
Mike
Old 12-20-2002, 10:23 PM
Mike. Thanks for taking the time to tell me how to do this. I will get to it shortly and post what I find. I've been busy lately. I Just didn't want you to think your helpful advice will be wasted.
