Old 03-01-2015, 12:00 AM
simboglide's Avatar
simboglide simboglide is offline
Re: Water Pump
which would also explain my new vibration...
Old 03-02-2015, 08:37 PM
simboglide's Avatar
Re: Water Pump
Alrighty,I didn't have the back cover completely flush so the tab on back of the cam sprocket was tapping the raised plastic around the cam sensor.took it all back apart, made sure it was all the way back and squared the timing belt on all the pulleys.reglued all the nuts on the covers with TPO and running smoooooth now!!
Old 03-02-2015, 08:39 PM
simboglide's Avatar
Re: Water Pump
Or the plastic has shifted/seperated/movet to the point of causing contact.
With the outer cover removed you can chect to see if the pulley is true.
You nailed it.
Old 03-02-2015, 08:40 PM
Re: Water Pump
Good yor you!
