Re: Persistent wheel bearing failure
There is no looseness in the system at all. In different parts of the country people call parts different names.
Ohhhhh, I see. Let me rephrase by saying, "I replaced that thar hub, yall".
Hey, Buda-Bing, change out dat part dare or I'll beacha wid dis bat thens, I'll stab ya inda eye! Yo!
Next time I am down there, remind me to tell you about some of my "family" stories. I have some REALLY GOOD ones....
Once I get closer to doing this job, I'm going to have our machine shop make some shims to go between the hub and the bearing-holder-hootus-thingy. Having not dug into that assembly yet, is there any reason this wouldn't work?
1996 SVX LSi : Work in progress, future garage queen 2013 Acura TSX: Mistake |
Sorry, I was too lazy to read everything. |
Shims are not really needed or possible.
+1... OT replaced my hub. Those bearings were being replaced about every 2 years. Now they are no longer an issue. Been quiet for quite awhile now.
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" |
"Used left rear hub ($177.40 List price)--------------NC" I BELIEVE that I actually changed the housing and called it a "hub". I went to subaruparts.com and they have the hub now listed for $177.30 list price, and the housing listed for $205.98 list price. It makes more sence to me that the price would increase in the 2.5 years since the repair rather than decrease. Since this thread began I have gone to two Subaru dealerships and no one can ever remember a reoccuring bearing failure. Right. I believe that a warped housing is much more likely than a warped hub (now calling it by it's Subaru name). The reason is this; When pressing a bearing out of a housing it can take 5 to 20 tons of pressure. Installing a hub never takes more than 152 foot/pounds.
I agree. After replacing the same bearings about 4 times, it wasn't until I replced the housing that my problem went away.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
Man, this job just keeps getting more and more expensive! Wish I could use the housings out of the donor car but they were howling when we parked it so that's not an option...
The '94 I just purchased is "humming" quite loud from both sides of the rear. When I questioned it, the PO said the dealer replaced the bearings less than 10k ago. I have gone ahead and purchased new OEM bearings, hubs (#28052PA010), seals, snap rings to cover all bases.
My questions are, what do you recommend to clean out the packing grease? NAPA sells a inexpensive plastic container and plunger for repacking. Is that sufficient. Just press and press the new grease until you think it's penetrated enough? Gene
#28
Then repack them by hand with a high temperature synthetic Asian wheel bearing grease.
