converter gaskets for a 97
I called Subaru dealer
here are the gaskets for main cat for obd2 96-97s 44022aa251 X 2 and 44022pa031 X 1 Last edited by kjoyes; 01-14-2014 at 04:48 PM. |
Re: converter gaskets for a 97
Edit:before I checked my part numbers, I assumed it was giving you the donut gaskets based off your quantities Last edited by 1986nate; 01-24-2014 at 10:17 AM. |
the only part number I see that would work for the front of the main catalytic converter are
is the 44022AA251 says quantity 2 my parts are on there way from subaruparts.com so if you can find the right part number soon I only have a 30 days to return the gaskets. Last edited by kjoyes; 01-22-2014 at 05:25 PM. |
Part number is 44022AA251 and you will only need one Peak under your car to confirm the cat was never replaced and still is the proper one. Meaning, it is still the flange style and not for some reason the type that uses donut gaskets and spring bolt assemblies. Last edited by 1986nate; 01-24-2014 at 10:15 AM. |
I am sure everything is original but what are you saying? do I need that part or not what flange gasket do you mean doughnut gasket
