Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #226
Old 08-08-2012, 06:33 AM
steveherman steveherman is offline
Re: ECU tune Transmission control unit?
Originally Posted by Nomad View Post
I'm selling 2 of these for 75$ each!
For a 4.44?
Old 08-08-2012, 12:38 PM
Nomad Nomad is offline
The car named NIGHTMARE
Send a message via MSN to Nomad
one stock and one for a 3.90.
Nightmare is the name of the car...
Old 08-14-2012, 06:40 PM
longassname's Avatar
Just some dude.
Significant Technical Input
I'll buy them.
Old 12-26-2012, 08:32 PM
Just some dude.
Performance FWD TCUs are available now. They are $350 and no core is required.
They have the same changes the performance all wheel drive TCUs have. As I have been doing for quite a while now I am publishing the changes so the information isn't lost should I get hit by a bus.
705503 BASECODE =94 US FWD SVX
MADE 12-26-2012
C025=E7:THRESHOLD TO TURN ON ATF TEMP WARNING LIGHT DECREASED TO 212F FROM F4
C026=DF:THRESHOLD TO TURN OFF ATF TEMP WARNING LIGHT DECREASED TO 203F FROM EE
C027=DF:THRESHOLD TO TURN OFF OVERHEAT MODE DECREASED TO 203F FROM E6
CO28=E7:THESHOLD TO TURN ON OVERHEAT MODE DECREASED TO 212F FROM E9
__________________________________________________ _________________________________________________
CEA2: NORMAL MODE IN D 1-2 (GEAR 1 UPSHIFT) SHIFT MAP FROM TCUMAPS.XLS
0F 00 80
1E 33 C0
3C 19 F0
53 00 F0
FF 00 FF
CEB4: NORMAL MODE IN D 2-3 (GEAR 2 UPSHIFT) SHIFT MAP FROM TCUMAPS.XLS
1E 00 80
3C 19 BC
5A 1B F0
95 00 F0
FF 00 FF
CEC3: NORMAL MODE IN D 2-1 (GEAR 2 DOWNSHIFT) SHIFT MAP FROM TCUMAPS.XLS (COPY OF POWER MODE MAP)
0F 00 80
0F 00 C0
2D 19 F0
FF 00 FF
CFAD: Power MODE IN D 1-2 (GEAR 1 UPSHIFT) SHIFT MAP FROM TCUMAPS.XLS
14 00 80
2B 16 B0
42 2C F0
53 00 F0
FF 00 FF
CFBF: Power MODE IN D 2-3 (GEAR 2 UPSHIFT) SHIFT MAP FROM TCUMAPS.XLS
28 00 80
51 0C AC
7E 18 F0
95 00 F0
FF 00 FF
__________________________________________________ __________________________________________________ ___
CA81-CA98: 3RD GEAR SOLENOID A MAP FROM SOLAMAPS.XLS
0F 00 1F40
2f 00 4a38
3f 00 4a38
7f 00 4a38
FF 00 4a38
ff 00 4a38
CA99-CAB0: 4TH GEAR SOLENOID A MAP FROM SOLAMAPS.XLS
0F 00 1F40
2f 00 4a38
3f 00 4a38
7f 00 4a38
FF 00 4a38
ff 00 4a38
Old 09-27-2013, 10:30 AM
Just some dude.
Needforspeed,
Do you have any JDM TCUs to sell? I'd like to know the cash price if you do and how many. Also, I understand you are tinkering with transmissions, I have some hard to come by upgrade parts I would possibly trade if you wanted.
Originally Posted by NeedForSpeed View Post
Jim,
The transmission is a 4EAT, four speed electronic automatic transmission. The gear ratios are 2.785, 1.545, 1.0, 0.694. Fourth gear, less than 1.0, is an "overdrive" gear. It could be said that the SVX has a three speed with an overdrive 4th gear.
You also have a locking 'TC' torque converter. The Subaru 4EAT is programmed to lock the torque converter in fourth gear. When the torque converter locks, the rpm will drop about 200 rpm. You can feel the lock, and you can see the rpm drop on the tach. It feels like a shift
