Old 07-01-2013, 05:23 AM
Kiss Me Deadly's Avatar
Kiss Me Deadly Kiss Me Deadly is offline
Send a message via ICQ to Kiss Me Deadly
which 3 cylinders are cut while shifting (stock)?
Subject Does anybody know it for sure? 1-3-5 or 1-2-3 or what?
Thanks
Subaru SVX LSi `95
Old 07-01-2013, 09:26 AM
Tapani Tapani is offline
Re: which 3 cylinders are cut while shifting (stock)?
No, but find the connector B59, pin 20 and measure the voltage. If the torque control is on the voltage shoud read 0V, if it's off it should read 5V.
If the TCU/ECU wire connector is not good (broken or shorted) you will have the torque control on all the time - or when the temp goes up in your case.
If I recall correctly this wire is cut when you install the QC - if there's a bad connection or something this might be the result.
I've had it..... bad connection - when going up hill the engine bogged down :-)
From the fuel injection manual, page 42.
Engine torque control B59 20 - - ON: 0, OFF :5
Good luck,
T
