Old 06-01-2013, 12:15 AM
kjoyes kjoyes is offline
heat shields Question
has any one tried too put dynomat on there heat shields to reduse the noise or rattle that they make?
Old 06-01-2013, 01:02 AM
reberto reberto is offline
Re: heat shields Question
I wouldn't, just because the smell would be appalling after a short while.
I just recently took all of mine off. It's quieter than ever
Old 06-01-2013, 05:22 AM
bishop bishop is offline
dynomat would be a terrible idea, its not meant to handle the heat, heat wrapping would be a much better idea.
Old 06-02-2013, 12:56 PM
An angle grinder works better
Old 06-02-2013, 02:17 PM
I went a little more ghetto, vice grips and a 10mm socket
Old 06-02-2013, 05:03 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Am I the only one who thinks that Subaru engineers put them there for a purpose? I just tweeked the shields and checked the connectors. Rust wasn't an issue. If you take them off, buy a fire extinguisher.
Gene
Gene and Ben
Old 06-02-2013, 05:32 PM
Yea! If you drive a lot off road and through dry leaves or park on dry grass... I took mine off in 2000 and never had a problem.
Old 06-02-2013, 06:01 PM
Gene
The purpose they serve is to keep your catalytic converters from igniting dry grass & brush and starting a fire. Having them in very dry areas serve a great purpose, not so much when you live in the super wet pacific northwest like I do.
Or if you just don't drive/park over dry grass ever.
Old 06-04-2013, 09:02 PM
I am thinking of putting exhaust wrap on pipes then the heat shields.
I am getting a lot of tinning of the shield when my car cools down.
only on one side I think of have a bad pre-cat.
