Old 05-01-2013, 09:42 PM
Tapani Tapani is offline
Head gasket swap w/o pulling the engine?
Possible? Worth it? I have a vehicle lift so it's easy to work from below also.
Tapani
Old 05-01-2013, 10:53 PM
Re: Head gasket swap w/o pulling the engine?
I'd just pull the engine. Esp since you're automatic and don't have to worry about taking a clutch apart and putting it back together. And that way you can clean up stuff and look around for looming problems.
Old 05-02-2013, 08:02 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Close to impossible. Think about how hard it is to change spark plugs.
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-02-2013, 08:22 PM
davew833 davew833 is offline
I know from experience that it CAN be done without pulling the engine. However, it does involve jacking up the engine sufficiently to raise the valve covers most of the way above the frame rails, so you have to unbolt the motor mounts. I didn't have easy access to an engine hoist when I did it, so I raised the engine. Knowing now how easy it is to pull the SVX (or most any Subaru) engine I'd definitely pull the engine if I had to do it again.
davew833@yahoo.com
Former 6-time SVX owner
Old 05-02-2013, 09:13 PM
Yes - I will bite the bullet and pull the engine for total disassembly while at it.
Thanks,
Tapani
