Old 04-22-2013, 08:42 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
EGR Port - What exactly is this?
I was looking through svx_commuter's locker for directions on how to test the ohms on the TPS, and I came across this picture labeled "EGR Cleaning Port":
I'd message him myself but his last activity was in 2009. Does anyone have an explanation as to what this does? Do I stick something in here and clear the EGR out with it? That would be fantastic!
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 04-22-2013, 08:54 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: EGR Port - What exactly is this?
I believe the egr valve lets in exhaust to mix in with the air intake for combustion. I believe it's to help reduce pollution.
If I remember correctly, you remove the cover to expose the bolts and remove it to clean. I did this when I removed the intake manifold to replace the vacuum lines. It was dirty with carbon, I used a small pick to scrap the inside to loosen it.
I am sure someone else can chime in with more information.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-22-2013, 09:11 PM
B 4 You's Avatar
#lolsvx
I hope so. I've been doing research for the last year trying to figure out an easy way to clean out the EGR without removing a ton of stuff... Also does anyone have a how-to on how to remove the EGR the hard way?
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-22-2013, 09:14 PM
Would like to know also what that is for...
Old 04-22-2013, 09:15 PM
dannmarr's Avatar
I work for my SVX
Do a search on intake manifold. There might be a write up about the EGR valve.
Subaru SVX for fun
Old 04-22-2013, 11:16 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
Exhaust Gas Recirculation valve.
Its both an emissions device and had impact on volumetric efficiency under certain conditions.
Main function is to recirculate a small percentage of exhaust gas back into the combustion chambers at the "correct" engine load to reduce NOx (nitrogen oxide) gases. When working correctly (can be finicky on the SVX) it will not rob any power from the engine. When not working efficiently, it can have negative effects on fuel economy and power just to name a few. The higher combustion chamber temperatures actually help to break down and displace NOx formulations commonly considered a harmful pollution especially in urban cities.
Its only actually actuated in the mid-band area of the power curve, never at idle or full throttle.
There is much more to the science behind this, but I just deal with non-working EGR valves, compliance, and basic reasons behind function. Hope this helps a bit.
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 04-23-2013, 01:14 AM
B 4 You's Avatar
#lolsvx
It does! Interesting how much one part can effect the whole car. But what exactly does that port do? Can one dump a cleaner in there and wash it out (seafoam)? Does one stick a pipe cleaner in it?
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-23-2013, 01:52 AM
bishop bishop is offline
I live somewhere without emissions so i removed the pipe and stuck a bolt in both spots to block it off.
Old 04-23-2013, 05:31 AM
michael's Avatar
michael michael is offline
What Potholes ???
The bolt in the picture I believe is a plug. Non California or pre 96 models use this plug in place of an EGR sensor.
Wanted: Steering Wheel
Old 04-23-2013, 02:44 PM
immortal_suby's Avatar
Thread Killah
Maybe these pictures can be of some help.
The bolt in the picture is not what the EGR actually plugs into. The EGR is a smaller pipe with a flange and 2 philips head screws holding it in place that are just about guaranteed to be stripped when you try to remove them. It is directly behind the top bolt that the picture points to.
I wasn't aware that you could clean the inside by removing that bolt - but it would be interesting to take it out and see.
Inside the tube will be a caked up mess.
Locker Link
2015 BRZ Limited 6MT
